Old 03-28-2015, 08:49 PM
an evening with RCA - service seminar booklet
"an evening with RCA", service seminar booklet from February 1966 -
60 pages, 20 MB pdf file:
http://www.bretl.com/tvarticles/docu...ithRCA0266.pdf
Old 03-28-2015, 10:02 PM
DavGoodlin's Avatar
Motorola Minion
Thanks for the treat. It confirms the best way to do PC board work is to stay on the top if you can
-Dave G
Old 03-29-2015, 10:08 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Clipping out the old part and soldering the replacement to the stubs on the top side of the board was standard procedure if you were fixing the set in the customer's home. Saved the time and effort of pulling the chassis to get at the bottom of the board.
I wouldn't recommend it for restoration work on vintage sets, though. Would really look terrible to see every cap and off-spec resistor in a set replaced in that manner...
Old 03-29-2015, 03:56 PM
I did that with this chassis
saved a fair amount of agony, and the less than pretty stubs are hidden from normal view anyway...
Old 03-30-2015, 07:12 AM
Marco-nix's Avatar
Thanks for the treat Old Tv Nut.
Old 04-01-2015, 06:07 AM
Raddion's Avatar
Raddion Raddion is offline
This is simply awesome. Thank you!!!
