Old 12-27-2011, 02:14 AM
gustavg gustavg is offline
Help me identify this old B&W Sanyo
Here is a little project i am working on, sadly the label at the back has been torn of so i cant identify the model of this tv. i would very much be able to have it identified so i could search for a service manual/schematic.
Excuse the dirt inside, this was prolly the first time it was ever opened
Also some of the tubes might be in the wrong place since i forgot to write down where they should go when i pulled them out to search for replacements(sorry im kind of a novice at this )
Gallery with the pictures in full resolution
http://imageshack.us/g/560/dscf4453p.jpg/
Front of the Tv #1
Front of the Tv #2
Back of Tv
Inside Tv
Some kind of number at the main circuit board.
Old 12-27-2011, 09:11 AM
marty59's Avatar
marty59 marty59 is offline
See if you can find any date codes and a stamped chassis number somewhere on the metal framing. That PC board number won't be much help..
At least if you can narrow down the date then it would be easier to do some Sams hunting and go from there.
Old 12-27-2011, 10:01 AM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
I can only guess at this point that it's an early 70s Hybrid set (tubes and transistors)
On the PCB, that looks like a date code, possibly 59th week of 1970?
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
Old 12-27-2011, 10:54 AM
i am going to ask the orginal owner when it was purchased and also going to photograph each number i find around the tv, thanks for replying
Old 12-27-2011, 12:38 PM
That set was not built for the NTSC market, so won't be any Sams coverage on it. When I first saw the picture, I knew it wasn't a set that I was familiar with. There was a metal plate on the back that stated the model number. Sanyo sets sold in this country used a combination damper and horizontal output tube. That set isn't that old. It was toward the end of the tube era.
Old 12-27-2011, 01:48 PM
marty59's Avatar
Aahh...would have had a 33GY7 or most likely a 38HE7 tube in it..
Old 12-27-2011, 04:09 PM
TerrySmith's Avatar
TerrySmith TerrySmith is offline
Do non-NTSC sets still use VHF-UHF tuners?
Old 12-27-2011, 04:18 PM
I have three multi-standard sets in my collection. They all have UHF-VHF tuners. IIRC, Britain is all UHF and the rest of europe uses both.
Old 12-28-2011, 04:21 AM
i talked to the orginal buyer and she says that it was bought in 1974 and behold..... she also found the orginal instruction manual with the modelnumber !
its a Sanyo 17-p60u or 17-p6ou depending on how you read it, i am going to pick up the manual later this week for some more investigations.
before this talk with the owner i identified most of the tubes that supposed to go into the tv and took some more pictures of different parts and numbers.
tubes:
1x 18gv8
1x 15dq8
1x 9a8
1x 16a8
1x 25e5
1x ??a?3 ( model# was torn away from the glass, see images below)
here is some more photos from the inside of it.
Old 12-28-2011, 09:16 AM
The tube in question is a 30AE3 damper. The other tubes and their uses are: 18GV8, vert osc & output, 16A8, audio output & 1st amp, 9A8 horiz osc & afc, 25E5 horiz output, 15DQ8, video output & sync. These entries are the most common uses of the tubes. Panasonic used a lot of these tubes in their hybrid color sets, before the all solid state sets.
Old 12-28-2011, 06:03 PM
David Roper's Avatar
console lover
So that isn't an optical illusion (if nj7p is correct) this set actually uses an octal HOT? Remarkable.
tvontheporch.com
Old 12-28-2011, 08:14 PM
The mid-60's Panasonic sets used that tube as well. I have a NOS 25E5 tube with the Arvin branding. I think they built that set to use the tubes readily available in Europe, as the Sanyos sold in the USA had tubes that were commonly available here.
Old 12-28-2011, 09:14 PM
TerrySmith's Avatar
That's a very interesting set, a newer model that uses a 25E5 tube.
FWIW, the Sansui 1000 reciever used four 25E5's for the push-pull audio out.
