Old 01-26-2011, 11:17 PM
stusnyder's Avatar
sencore ps148 scope
Anyone familar with this scope? Just picked one up, nice working condition with the probes. The unit has 2 multi section can ecaps in it, and a few carboard style ones, which I'm going to replace.
Is this a decent scope to use on older radio's and early tv's?
Old 01-27-2011, 01:58 AM
bob91343 bob91343 is offline
I don't know Sencore stuff but I had little respect for the company. They seemed to cater to the short-cut, low intellect kind of repairman (I won't say technician). Maybe it was just the way their stuff was presented.
Having said that, I imagine their stuff worked and if you have a 'scope it might be worth refurbishing. How old is it? I'd lean toward not fixing anything that ain't broke.
Old 01-27-2011, 04:57 AM
stusnyder's Avatar
not sure on the age, no copyright date in the manual. says it's a 5 inch scope and vectorscope. Probes came with it, and the original box.
Old 01-27-2011, 11:34 AM
I always thought Sencore equipment was too expensive. They always had super-pricey analylisers that had limited use. I thought B&K was good value for the money.
Old 01-27-2011, 01:16 PM
I agree. Actually much (if not all) of the older B&K test equipment was made in Japan by Trio, also known as Kenwood.
Old 01-30-2011, 09:32 PM
Agreed - Sencore was pricey stuff, better to buy used from the dealer/technician that thought all those pricey tools were the key to making money. Most that bought the marketing BS went belly up. I was anti-Sencore up until the VA48 and VA62 could be had on the used market. Those two analyzers, with the B&K 1076/1077, are the cat's meow. I'll add the LC101/LC102 and CR70 as must-haves for me.
B&K CRT checkers were our staple - the 440, the 467 and the 470 (favorite, by far). B&K scopes were rebadged Kenwood/Trio and Kikusui, not bad for the value, but their sub-15 MHz bandwidth stuff is junk.
As for the OP's scope, it's probably a 5 MHz bandwidth scope, pretty easy to use and maintain.
Cheers,
USN RET 22YRS (Avionics/Cal)
