Old 02-17-2009, 09:09 PM
Dan Schafer's Avatar
Dan Schafer Dan Schafer is offline
Danny in Cleveland
RCA F19430 Wind strom outage
Hi All
My neighbor asked me to look at their two TVs that will not come back on after a power outage from a wind storm we had a week or so ago. One is an RCA model F19430, chassis CN-001N. I can't find it in Sam's, is there a CTC # for this set? The fuse is open and the regulator IC (MA8630) is shorted between all 7 leads. Just wondering if there is something further I should check before I replace the IC & maybe have the new part blow again? There is no NTE # for it & MCM has discontinued the IC. Where can I get one? MCM had it at one time for $14.49 (not too cheap!). Sigh...another landfill addition, I suppose.
Hopefully their other TV, a 42" Sanyo (AVM3651G) will be just a fuse...at least there is a Sam's for that one.
Thanks in advance for anyone's 2 cents.
Old 02-17-2009, 11:16 PM
That's a Daewoo chassis and probably not worth the effort. I tossed a couple of those a few months ago. One had a bad regulator IC and the other had a bad flyback. You might try www.tritronicsinc.com for that IC. If they don't have it at a reasonable cost, I'd probably junk it.
You'll probably have more luck with the sanyo. Check the rectifier diodes and the voltage regulator transistor if the fuse is blown.
