Old 12-10-2007, 05:10 PM
Dud 23VCHP22. Rebuild or toss?
I just junked an early '70's Curtis Mathes solid state TV/stereo combo. The only reason I brought it home was for the tube; but, it turns out to be bad (thanks to instant on, I'm sure). I rejuved it and got the red and blue up good; but, the green didn't do as well. It is a 23VCHP22 with an EIA code of 337 (Westinghouse) and it's a non-bonded type. Would it be worth rebuilding this for a spare or would I be better off just to toss it?
You know, for those CM sets to cost so much in the '70's; they sure were cheap made. This cabinet is all particle board and plastic. The TV chassis was an NEC and I don't know who made the stereo chassis. It looks like they just shoved the cheapest thing they could find in there. IMHO, the '70's Zenith's and RCA's were much better made.
Old 12-10-2007, 05:40 PM
MRX37 MRX37 is offline
I guess your answer would be based on how hard it would be to rebuild the tube, and how badly you need that type of tube.
Old 12-10-2007, 07:41 PM
Right now I don't need it that bad but it seems that 23" delta color tubes are a little hard to find (around here).
Old 12-10-2007, 08:52 PM
I'd keep it until you need the space, then toss it if you have to.
Old 12-10-2007, 10:46 PM
That's what I think I'll do. I may run up on a TV with a busted tube and at least this one can be rebuilt and used if needed. Of course, if anyone here needs this tube, just let me know. It will be free.
Old 12-11-2007, 12:41 PM
I think it will be quite awhile before we run out of good 23v tubes. There are still some NOS turning up. That being said, I always hesitate to toss a dud. As long as there is room in the attic I hold onto it-you can always toss it later.
