Old 12-06-2007, 12:22 PM
Snade's Avatar
Snade Snade is offline
humble AK member
Little Help >> how to set channel buttons on old Trinitron TV
On this set, there are two buttons near the bottom of the vertical row of buttons that can be set to any channel. How do you change the settings of these buttons ? There is no remote.
Thanks for your help.
Sony KV-1923 from the early 1980's.
Cheers, Snade
Old 12-06-2007, 01:03 PM
Duane's Avatar
Duane Duane is offline
Nice looking Sony. We have a KV-1915 at work with the same button layout as your KV-1923. Those two bottom buttons could be assigned to whatever you desire. They are adjusted just like channels 2 -13 you show in the pic. You open the door and behind it you'll see a knob or thumbwheel (the KV-1915 uses a thumbwheel, my KV-1946R at home used a tool to turn a knob).
This knob or thumbwheel fine tunes the selected channel range that you can select by a 3 position switch close to the thumbwheel.This switch selects the channel range. Far left would be 2-13. Middle would be 14 and above.I don't recall how far that middle selector goes. The far right would be the upper channel range,again,those numbers escape me.I don't believe they go to high.Maybe someone else knows exactly. Each pushbutton switch on the front of the set has it's own set of switches and thumbwheel/knob adjustments.Hope this helps and is what you're asking.
As a sidenote. The channel designations you see on the front could be changed by inserting another number into the selected slot. Problem is, those numbers are generally lost.
Old 12-06-2007, 01:26 PM
Snade's Avatar
humble AK member
Duane, thanks a million.
I did not see that door in the lower right.
Snade
Old 12-06-2007, 02:13 PM
Any of those buttons can be set to any channel. The idea is that you program all your local channels in and then replace the numbers with the correct number. It probably wouldn't be that hard to reproduce the numbers by laser printing onto a transparency.
Old 12-06-2007, 09:55 PM
The little black rectangle below the list of channel numbers is a handle for a plastic strip that pulls down and out. On the strip is currently a long thin piece of plastic with the numbers 2-13 and the two asterisks, but the set originally came with a sheet of all the individual channel numbers. I used to set those up for customers and friends all the time around 1980-84.
