Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Movies, shows, & programs
Old 12-19-2008, 02:40 PM
soundmotor's Avatar
soundmotor soundmotor is offline
super modified
Originally Posted by eteller View Post
Magnetic clutch, you could have it slip too, so you could have full boost at lower rpm, then slip as the motor's rpms rise. Would be easier to do on a Eaton type supercharger
On nearly every car forum I can think of over the years this topic inevitably comes up. Some pretty creative solutions get posted from using A/C clutches for the drive pulley to bypass intake ducting using vacuum operated solenoids. It is pretty funny how large this prop looms in the minds of so many gearheads, mine included. Hearing the belt slap & whine on start-up, you just know it's go time.
I took a hammer to a Regency TR-4, I was 6 at the time.
Old 12-19-2008, 02:49 PM
elcoholic's Avatar
elcoholic elcoholic is offline
Lonesome LA Cowboy
Why take the fun out of a blower motor? The whole point of a blower is having a motor that keeps making more and more horsepower until it grenades or the rev limiter steps in for the faint of heart. I once had the pleasure of taking a real '65 GT350R (legit numbers car) with a Paxton to 55 mph in 1st. The sound that 289 made through the side dump Tri-Ys and glass pacs was a near religious experience.
... hanging out and hanging on to your window ledge calling your name from midnight until dawn
Denon, Dual, NHT, Oppo, Yamaha, B&O, Bogen, Onkyo
Old 12-19-2008, 09:16 PM
lguise's Avatar
lguise lguise is offline
Definitely Low-fi
finding a way to engage or disengage the belt is not the problem. getting air into the motor with the blower not spinning is the trouble. a roots type supercharger (blower) has to spin for air to pass through it. also, blowers don't make more and more horsepower either. as the engine rpms climb, the blower looses its effects. turbochargers are the opposite, they don't boost much at lower rpms. that's why there are so many combos on the market.
mad max was a very cool movie anyway!
pioneer sx-780, mcs 6601 w/empire a22me, homegrown frankenspeaks
Old 12-20-2008, 12:05 PM
elcoholic's Avatar
Lonesome LA Cowboy
Agreed, on a dyno anyway but I was oversimplifying. Ignoring safer OEM limitations and with the right gearing a brute force blown set up for drags can be redline limited while the HP curve is still fairly steep. That's the fun I was talking about, pinned to the seats all the way through the gears till you run out of rpm.
Factoid: I once read that the blower on your basic 9000 hp top fuel car consumes 400 hp.
Old 12-20-2008, 02:56 PM
soundmotor's Avatar
super modified
I am thinking that is a pretty small percentage of the overall HP and there are no alternator or water pump losses either.
Old 12-23-2008, 12:34 PM
eteller's Avatar
eteller eteller is offline
What's a cd?
That's why you would use an Eaton type SC, it could be bypassed easily.
Ed
Technics SL-1700mk1, SL-D3, Yaqin MS-12B, Onkyo M501, Klipsch KG 4.2, and lots of home theatre junk
Old 12-25-2008, 01:30 PM
Kptn Howdie's Avatar
Kptn Howdie Kptn Howdie is offline
perhaps the reason for the on/off was keeping in the theme of fuel conservation since gas was in short supply but the blower acted as the hp boost when needed to power away from the bad guys, or catch up to them..............
the night rider lives!!!!!!!!!
