Old 08-18-2019, 03:13 PM
Popester's Avatar
Popester Popester is offline
Chris, I want to revisit post #14. You seriously gave that a wash, I understand that it wasn't a pressure wash. But how can getting IF cans wet or the innards of transformers wet not do some type of permanent damage to those components?Spats Bear has a YouTube video of a Zenith Chromacolor chassis that he puts through a kitchen dishwasher. Never thought that you could wash electronics, not that I want to start, but it sure does clean things up. But what about the long term left on residual chemicals left on after doing a chemical rinse. Wouldn't that damage or shorten the life of a fragile IF transformer? Please elaborate, you got my attention now. Wow.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 08-18-2019, 04:11 PM
Standard procedure at Tektronix for refurbishing test gear included washing (as told to us at Zenith by the Tek rep). I don't know what kind of detergent may have been used, and would imagine that distilled or deionized water was used for final rinse.
Old 08-19-2019, 09:20 AM
trinescope trinescope is offline
I think as long as the chemicals aren't too harsh and you get the equipment dried quickly there won't be a problem. The only time I had problems washing something was the chassis in a low end Curtis Mathes stereo console, and that was in the AM IF transformers which used the troublesome internal mica wafer capacitors, so they would have had problems anyway. I subbed in transformers from a junk radio chassis not knowing that I likely could have repaired the originals. Everything else on it worked OK, and I was able to get rid of the dirt and cigarette tar.
Erich Loepke
Old 08-19-2019, 11:04 AM
I've been known on chassis that smell moldy or are hideously dirty to spray them down with the garden hose in jet mode then sun dry... hasn't caused me any issues yet... granted I try to minimize aim at transformers.
Old 08-19-2019, 11:34 AM
What do you mean by a "chemical rinse"?
Old 08-19-2019, 12:58 PM
Yesterday I tackled the yoke cover. Just the side of the yoke cover was in bad shape. the top and bottom were ok. After removing the cover, I chipped off the side and left the bottom.
I then made a new side using 1/32 plywood. After fabricating the new side, I soaked the outside using CA glue as a base for the primer. I sanded it then shot some primer on it.
Once dry I installed the new side and used some 5 minute epoxy to glue it to the bottom. Once dry, I then painted it gloss black.
Old 08-19-2019, 01:26 PM
Popester's Avatar
Chris, what I meant by chemical rise is that usually at a car wash the final rinse isn’t just water. It’s water and some kind of a rinse agent. Whatever the rinse agent is what I meant. Buy the way that’s turning in to a very nice restoration.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 08-19-2019, 01:30 PM
The final rinse is de-ionized water. "Spot Free" rinse at the car wash.
Thank you,
Old 08-19-2019, 06:21 PM
I aligned the chassis today. It went well and quick. This thing plays well. The chassis is as far as it will go till it is installed back into the cabibet and all the picture controls can be adjusted.
On to the radio. Still no documentation.
Old 08-19-2019, 06:52 PM
On what appears to be an AA6 with PP audio like that as long as the values have not rubbed or burned off the components it is pretty easy to restore them without a schematic...Simple sets like that I often don't even bother to get a print while restoring (except for the occasional problem child).
Old 08-19-2019, 07:37 PM
Yep, that's what I'm banking on. Stay tuned.
Old 08-19-2019, 10:12 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Today I continued to recap the chassis. This TV has a couplate for the Vertical Integrator. I remembered I made one up that seemed similar on another project. I checked my docs and sure enough it was identical. When I made the first one up, I made 2 boards. I dug around and found the second board. I then proceeded to make up a new V. I.
On those vertical integrator modules/PECs what type of capacitors are you using?
Old 08-19-2019, 11:04 PM
Originally Posted by mr_rye89 View Post
on those vertical integrator modules/pecs what type of capacitors are you using?
mlcc
Old 08-19-2019, 11:33 PM
mr_rye89's Avatar
the vertical integrator in my TV calls for 1000pF and 2000pF capacitors, will subbing ceramics there screw anything up?
Old 08-20-2019, 12:02 AM
I don't know. Maybe someone with the electronics background can answer that question.
