Good TV by most accounts and personal experience. The 15LP22 appeared to have a better picture than larger CRT's using low-focus voltage. I liked working on these more than the tubed 19" RCA portable color sets because you knew when it was "done".
Open HV box, power up, turn out the lights and snap a picture of what arcs. Look for purple lightning or arcing flares. A loose-missing ground wire-spring to CRT dag coating may also exhibit arcing. The trick is to see where that arcing is happening. I have not seen one of these in years and forget the HV rectifier tube socket arrangement, but always clean everything real good like Tom advises. If there is an arc-hole burned through the HV tube socket-cup assembly, it is probably available from Moyer's Electronics. Fixing a carbon-tracked cup is possible and I have done it using a Dremel to remove burned/tracked material then covering with RTV silicone. The 5GH8 tubes are used for multiple functions in this set and may be an issue but the other tubes rarely needed replacing. Either way, those may need attention AFTER fixing the arcing issue.
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 08-18-2020 at 01:04 PM. Reason: remove redundancies to previous post. |
