Old 08-13-2015, 07:08 PM
When it comes to variacs and isolation transformers one thing to keep in mind is the failure mode is overheat....If you need to run a set with a higher power consumption than they are rated for it is perfectly safe to do so for several minutes provided you monitor temperature and avoid overheat.
