Old 04-28-2014, 06:18 PM
coppercity coppercity is offline
Apple CRT Display, thin green line no picture.
Greetings, I have an old Apple CRT from about 1996, It makes a loud buzzing sound and only displays a green line that runs from the center of the screen to the bottom.
Any ideal on what the problem is and if it's fixable? I know about the high voltage's ect.
Old 04-28-2014, 06:24 PM
lnx64's Avatar
lnx64 lnx64 is offline
Model? I have service manuals for Apples 90's CRTs.
Old 04-28-2014, 06:27 PM
Model is M2943 15" Muilt-scan. Thanks.
Old 04-29-2014, 12:08 AM
lnx64's Avatar
Here's the service manual: https://www.mediafire.com/?41swvh55xwtav2l
Hope it's the right one.
I'm not sure exactly where to check, but it sounds like you have no horizontal raster but some vertical?
EDIT: Woops, that's the user manual. Hold on I "should" have the service one for this.
EDIT2: Turns out that IS the service manual. Wow that's crappy. I hate to see what the user manual is, how to plug in and that's it? Jeez. :/
Sorry.
Old 04-29-2014, 12:25 AM
Thanks, Ya that's pretty sad for service info, everything says return to apple. I don't know a lot about CRT terms, but all I know so far is it makes a loud buzzing noise and has a thin green line that runs from the bottom middle of the screen to dead center of the screen and stops.
Old 04-29-2014, 12:27 AM
lnx64's Avatar
Think you can get us an interior picture? I want to say caps, just because I like saying caps, but it may be something else. I wouldn't run it again though until it's figured out.
Old 04-29-2014, 12:35 AM
Sure, I will get photos tomorrow. I got the entire system in it's box a Powermac 7200/120 from an e waste drive. I am not even sure the computer itself is working, It turns on I get a chime and then I just get what sounds like a chirp over and over again. don't know if thats from a bad battery or the monitor or both or it's normal. No I won't run it until I get it fixed.
Old 04-29-2014, 12:50 AM
lnx64's Avatar
I have a PowerMac 7500, a constant reboot to a chirp is not normal and it should run even headless. May have a corrupt system file (or some crazy app that's running), but if you aren't hearing a death chime, you're good so far.
Old 04-30-2014, 12:37 AM
Rod Beauvex Rod Beauvex is offline
The lead ear.
If you're not wanting to mess with fixing the display, you can buy one of these and use any VGA pc monitor.
http://www.amazon.com/Cables-02902-F...X7CE1519565HJ5
Old 04-30-2014, 08:18 AM
I do want to fix the display, but don't have any time right now. That is a good quick way to get the system up and running. Thanks! I will try to post back some photos when I open it in the next week or so.
