Old 09-20-2011, 11:03 PM
Bill R Bill R is offline
B&k 465
I could use the setup manual for this CRT tester since I misplaced mine. If anon has one rhey could scan I would appreciate it. A 12lp4 CRT found it's way to my place a couple of days ago. Looks like it is good, but I don't remember the settings. I don't want to restore it, just test the emission. Of course this means that if it is good I will need to find a set to put it in. Anyone close to west tn with a set that needs a CRT. I would be interested.
Old 09-20-2011, 11:21 PM
Bill,
Google turned up this.
http://home.comcast.net/~mtpacifico/...5%20Manual.pdf
Not the best scan, but I think you can fudge your way through it.
Old 09-20-2011, 11:35 PM
Adam's Avatar
Adam Adam is offline
settings for 12Lp4 - G2 = 250, G1 = 18-58
I just bought an Emerson 612 that has a 12LP4 in it, that's supposed to have a 10BP4. The 12LP4 doesn't even really fit in the cabinet. If you only had a 10BP4 rather than yet another 12LP4...
Old 09-21-2011, 12:12 AM
Thanks. Using those settings the emission reads full scale, and cutoff is just over 20. Life test looked good as well. Looks like now I need a tv to put it in.
Old 09-21-2011, 12:17 AM
I know this is a common tube, so what sets used this tube?
Old 09-21-2011, 12:46 AM
Off the top of my head:
Admiral 22X12, 24C16
Crosley 9-407M
Motorola 12K1/2
Philco 50T-1401/2/3/4
Plus many others...
Old 09-21-2011, 12:42 PM
Hi Bob, thought about you when it showed up. The electrician that is doing some wok on my bathroom stopped by one afternoon and said he found something I might want. He had the tube sitting in the cab of his truck. Seems it was just sitting by itself in the attic of a house he was working on. The only thing he knew was that it was a CRT so he gave it to me. He collects fans so I will have to watch for fans. I told my wife that since the tube is good I will have to find a set to put it in. Maybe a table model would be best.
Old 03-17-2012, 11:46 AM
charokeeroad's Avatar
charokeeroad charokeeroad is offline
John Q
Bill,
Kevin Thanks. I have been looking for a link for that manual for some time.
Old 03-17-2012, 11:48 AM
John Q
Adam, Does you Emerson 612 look anything like my Avatar?
