Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 10-08-2009, 09:35 PM
Findm-Keepm's Avatar
Followin' the Rules...
TWO stories: CRT Implosion and Boost, Injected!
My only "serious" incident occurred the summer when I was 17. I was helping my Dad swap CRTs (25AXP22's) between two sets at his TV shop. I pulled the bad CRT out of the set and set it on the dump pile outside, then busted the "tit" to let it go to air, no problem. Dad, meanwhile, left to go get a new blue lateral assembly at the parts place a mile away. I was alone and with the vigor of youth, decided to pull the "good" tube to have it ready when Dad got back. I unbolted it just fine, and I lifted it from the set (by the neck) and set it on the edge of the cabinet to reposition it. I then hoisted it up by the sides (face down), only to have the 2nd anode button come in contact with my abdomen and now-sweaty t-shirt. WHAM!! - I got the residual charge. I reacted by pushing it away from me, into the corner of a workbench, imploding the CRT about 6-8" from me. I was shaking, and alone, and uninjured. My only scare was what was I going to tell Dad when he returned. Thankfully, he laughed it off after ensuring I wasn't hurt. Glass shards were everywhere, and we even found some 6 months later when we moved some equipment around in the shop.
And now, Dad's:
Dad was working on a hybrid Magnavox 19" color set and was reaching in to do something when the back of his right arm contacted the screen controls and +570 volts of boost. Now the screen controls on this Maggie were the type with wire wrap terminals - those long, sharp ones that will dig into your skin if you jerk back suddenly, as Dad did. He had the presence of mind to pull the cheater cord, and ended his trauma. Thankfully, the current only conducted along his arm from fingertip to forearm, but the damage was done. He saw a specialist who diagnosed nerve damage, no treatment. Dad could lift a coffee cup only so far before he would lose control and loosen his grip. It took him about a year to heal up from that one. He's had close calls since, but he talks about that one the most.
Live and learn they say.....
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-08-2009, 10:23 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Your belly-button was smokin!
Charlie Trahan
Old 10-10-2009, 01:08 AM
I know! Had I done something like that to our TV, I wouldn't have been able to sit down for a month.
Back around '95, one of my classmates brought an early '70's tube type 19" RCA color TV to our electronics class in an effort to sell it to me. Even in '95, I was shocked to see that he had a 20+ year old tube set. He said he had a new TV in his room; but, got mad one day and shot it while it was on (I wonder if he was related to Elvis). I asked what his parents thought about that and he said his dad laughed about it. I think I gave him $10 for the tube set. I'm surprised he didn't destroy it just because it was "old". Once again, it would have been hell to pay had I done that. First, I would have gotten my rear end beat. Then, there would have never been another TV in my room, even if it was one that I obtained on my own. I would not have mattered that I was a teenager. My Dad's rule was "As long as you're living under my roof, you follow the rules".
Old 11-01-2009, 08:38 AM
larschr's Avatar
larschr larschr is offline
TeeVee collector
About ten years ago, one of my friends found a Playstation (the first version) in the trash. We hooked it up to a TV and the mains and hit the power button - but nothing happened. So we removed the top cover and quickly noticed that the power supply fuse was blown. Well, that was no big deal, we replaced the fuse, plugged it in again and hit the button a second time and heard a loud "snap" as the fuse blew. But we decided not to give up that easy, so we bypassed the fuse with a piece of 4mm2 wire. "I assure you, this will not burn over" was my friends last words before he put the plug into the 230 volt 63 amp 3-phase outlet. The ceiling lights dimmed, we heard a loud 50Hz "BZZZZZZZ"-sound and flames were shooting out of the power supply. In a matter of seconds the whole Playstation console were engulfed in flames. When we got the fire put out, the Playstation's main transformer were completely gone, and the only trace of it was a hole in the circuit board. Needless to say, that Playstation went back in the trash.
Old 11-01-2009, 03:32 PM
crtfool's Avatar
crtfool crtfool is offline
About 17 years ago, a friend gave me a nice VCR that was dead - no display, and no LEDs lit up when plugged in. I replaced a blown 2A fuse, which blew immediately when I plugged the VCR in. I tested all the power supply components, but could not find anything that was shorted or obviously defective. I tried another 2A fuse, then a 3A and a 4A - same result. I was determined to find the cause - it was the VCR or ME, and I was not going to lose to a stupid machine. I connected my multimeter to the fuse holder and set it on the 10A high amperage setting. Plugged in the VCR and stood back - the VCR powered up briefly, the meter quickly rose to just above 7 Amps, and then 1 of the transistors on the power supply exploded! I replaced the transistor and put in another 2A fuse - VCR worked perfectly for about 5 years after that without any problem.
BTW - I would never use a paper clip, piece of wire, or tin foil to bypass a fuse!!!!!!!!
Old 11-01-2009, 03:37 PM
Charlie's Avatar
On Land
Originally Posted by crtfool View Post
. Plugged in the VCR and stood back...
That part of the story, by itself, absolutely cracks me up!!!
Charlie Trahan
Old 11-01-2009, 03:42 PM
crtfool's Avatar
HEY - I'm no FOOL!! I wasn't getting anywhere near that thing when it went!
Old 11-02-2009, 03:50 PM
Zenith26kc20's Avatar
Zenith26kc20 Zenith26kc20 is online now
Best was a UPS specifically designed for Audio and video high end systems. Sorry, no names mentioned but it big and heavy (1500 watt, sine wave, always on line, no standby). With the system playing, I unplugged the UPS from the wall to let a friend hear the difference from plugged in and on battery.
About three minutes later it sounded like a shotgun went off in the house. The stereo was still playing! Another louder blast and everything went off.
Flames came out the back and I (I know, not a bright thing but panic will do things to you) pulled it from the rack and threw it in the back yard where more smoke and noise continued!
A few Heinekins later it was finished. What a stink! I boxed it up and sent it back. The company replaced it with a refurb which lasted about three months and went dead. No excitement that time.
I use a different brand UPS now......
Old 11-03-2009, 01:38 AM
zenith2134's Avatar
I have a story but it isn't mine, it was my uncle's from the mid seventies. Brand new color Zenith 25", fourth floor window, and anger. LOL Supposedly it " blew up in the backyard real good "
Old 11-03-2009, 07:10 AM
Not quite as spectacular, but I remember a story at AK a few yrs ago about a couple of guys who rescued an old console radio from a barn/shed, loaded it up in a van, set out & suddenly had 17,234 VERY angry waspers to deal with...
Old 11-03-2009, 07:45 AM
Charlie's Avatar
On Land
Originally Posted by Sandy G View Post
Not quite as spectacular....
I bet those two guys would beg to differ!!
Charlie Trahan
Old 12-24-2009, 09:06 AM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
When I was about 12, my neighbor, an old man who lived alone, passed away. A few months later, there was an estate sale in his house. I was immediately drawn to a 1951 Hallicrafters TV in the rear addition, price: $ 10 (had raster/no pic/no sound). I really wanted this set, and begged for $10 from my parents all afternoon. My mom said "there's no room", and "we can't afford it" (B*******, I was one of 5 kids, my mom couldn't watch us all, and she would not tolerate my watching TV unsupervised).
In order to shut me up, they consented to giving me $5 to buy the table radio atop the TV, which I did.
This old radio sounded pretty good, with deep bass, and I made fairly good use of it for several months, until the family cat chewed the power cord.
So I bought an extension cord, cut off the socket end, and wired it to the old radio. The radio's old cord had three wires, so I wired the cold to the cold of the extension cord, and both of the others to the hot.
Then I plugged in and turned on the radio, fully expecting to enjoy some music. My eyes were greeted with a brilliant flash of white light from the loctal tubes inside the partially open cabinet, and no sound. Soon after, the radio went out with the trash.
About 8 years after this, I would learn that the third wire was for the old resistor line cord, which dropped the 120v house current to 30v, powering five (?) 6v 300mA filaments in series, and distributing the remaining heat (90v x .3 A = 27w) along the length of the cord. My replacement toasted the tubes with 120v.
About 22 years after this, I would see a radio just like mine in a completed auction on you-know-where.com. The Detrola radio, with cream bakelite cabinet, China red knobs and trim, fetched over $ 600!
Old 01-02-2010, 01:22 AM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
When I was a wee lad of 10 the TV repair man was called one day to diagnose and fix a no picture but sound only problem on the family 23" Silvertone b&w set. The TV guy quickly found an intermittent electrode in the gun of the picture tube. The fix was to use the blunt end of a screwdriver and give the neck a couple of taps. Apparently, these were supposed to be "gentle" taps. The guy left the back off the set so Dad could give the prescribed treatment. Well, about a week later the set acted up, Dad wasn't around, and Bug Bunny just couldn't wait, soooo.... I got out the screwdriver and gave the CRT neck a few good whacks ...while the set was operating! ZAP, WHOOSH, sparks, sizzle, smoke, and stint of burning varnish and plastic filled the living room. I hit the neck so hard it cracked and all hell broke loose as air entered the CRT. Oh...that model operated at 20KV. Burned a nice hole clean through the deflection yoke. Fortunately, I wasn't hurt but did get a good scare.
