  #34
Old 10-10-2016, 04:54 PM
Originally Posted by tom.j.fla View Post
Ah yes forgot about the 45EC4, could not find them when the set was new. You had to try to get them from Panasonic. Starting about mid 1974 started using RCA double damper diode for the CTC22 color set to replace the 45EC4. Worked great,you will need 150 ohm 15 watt resistor to take place of the tube heater. Good luck finding that damper diode though. Looked but couldn't find the ECG number. Well good luck getting it going. All the best Tom.J p.s. Nte part number for the RCA damper is ECG/NTE173BP.
Thanks for the advice. I'd like to make do with what I have so if I don't have one (I've got some real oddball pulls so there's always a chance I may have one somewhere), then I may try making another damper tube work in that circuit...I've got some wacky series string dampers sitting in boxes with nothing better to do.
