Old 07-17-2011, 03:28 PM
ctc17 ctc17 is offline
SCOTT PROJECTION TV 6T11 (craigs list bargan)
http://losangeles.craigslist.org/lac...488928873.html
ANTIQUE PICTURE TUBE RECEIVER SCOTT PROJECTION TV
OVERVIEW:
The Scott TV appears to be the model 6T11(there is no model number on it at all), in this case is a television from the late 1940's built by Scott Radio Laboratories from Chicago Illinois.
This table top television functions by using a vertical tube to project the received image to a mirror which then reflects the image onto a ground glass screen for viewing.
SPECIFICATIONS:
* Scott projection TV
* Black & white television, channels 2 - 13
* 31 tubes, UNTESTED
* Controls: focus, brightness, contrast, volume
* Ground glass screen size: 19" wide x 13" high, 23" diagonal size
* Wooden chassis
* Overall dimensions: 25" width x 22.5" depth x 14.5" height
* Input power: 105 - 125 volts AC 60 Hz, 1.9 amps rating
Unit appears to be complete, still might have some parts missing, tubes are untested, comes with everything as pictured.
Also comes with photofact folders with a large folded schematics for the TV, adjustment of optical system, dissassembly instructions, removal of projection tube, parts list and description.
GOOD CONDITION! vintage condition, has some scratches, overall pretty clean and good cosmetics for it's age. Viewing screen(frosted glass) has some damage with faded painting on.
USED, UNTESTED, NEEDS WORK, SOLD AS FOUND.
FREIGHT SHIPPING AT YOUR EXPENSE OR LOCAL PICK UP ONLY.
Tritium Electronics: 414-475-007, www.beercityaudio.com
it's NOT ok to contact this poster with services or other commercial interests
image 0 image 1
image 2 image 3
