Old 08-13-2015, 08:12 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Value of this micamold?
I'm horrible with these. Can anyone give me the value of this cap?
Thanks!!!
Old 08-13-2015, 09:16 AM
Kamakiri's Avatar
This cap goes between pins 4 and 5 of the 6J5 in an RCA 8TS30. I have this cap at .0047 now from the RCA factory manual. This is one of the "larger" Aerovox caps. I'm having vertical drifting issues with this set, and thought I'd replace it. Do I need a mica here or is it a standard cap?
Old 08-13-2015, 09:24 AM
oldtvsandtoy oldtvsandtoy is offline
Banned
Did you check here? http://www.tpub.com/neets/book2/3g.htm
Old 08-13-2015, 09:38 AM
ChuckA's Avatar
ChuckA ChuckA is offline
Thanks!!!
4700pF / .0047uF
White= Mica
Yellow = 4
Violet = 7
Red = x100
Green = +/- 5%
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
Old 08-13-2015, 09:39 AM
Kamakiri's Avatar
That's the problem, this is an Aerovox with no distinguishable arrow. But as I mentioned, I ended up identifying it in the RCA manual as a .0047. Now I just need to know if a standard cap will work.
Old 08-13-2015, 10:05 AM
ChuckA's Avatar
You probably want to replace with a mica, but a regular poly will work to see if it fixes your problem
Chuck
www.myvintagetv.com
Old 08-13-2015, 11:18 AM
John Folsom's Avatar
Sams IDs your cap as 4700pf @ 500VDC, which would make it a silver mica. However, as Chuck said, a poly will work well enough to allow you to diagnose your problem.
John Folsom
Old 08-13-2015, 12:53 PM
Kamakiri's Avatar
Having a vertical linearity issue, replaced some out of tolerance resistors on the last go-round. Stuffed in the .0047, and it seems about 50% better. Not 100%, but much better than it was
