Old 09-09-2006, 12:29 AM
ARC Tech-109
Guest
Posts: n/a
Magnavox Astro-Sonic Combo Is Complete
Well this evening I put the finishing touches on my Astro-Sonic combo set and I gotta tell ya it works great! Before I start in with all of what I had done I want to thank all the members especially Randy Bassham who pointed me in the right direction with the exact chassis number of the TV receiver itself.
So far I have replaced the Pix tube twice, original was very weak to begin with and the second tube would loose the green gun over a few days time if left in the instant on position. I could shoot it with my B&K 467 but it would fall down again and the last dusting of the gun turned into a K+G1 short. Ended up dropping in another 25XP22 NOS tube.
Ive also replaced all of the resistors on the horiz/vert/pin board, most of the resistors on the video board and several on the IF strip along with clipping out the OE supply caps and subbing in 450v low-loss photo caps. All the tubes are NOS american mades along with what I suspect are Telefunkin 6GH8's in the chroma circuits.
Now I know this is gonna upset a few purists but I also added an older FRED MTS decoder and tapped off the sound IF to feed it, split the mixed audio line in the stereo receiver for TV and subbed the solid state amp with a Heathkit AA-100 chassis right under the turntable. The output transistors were shorted along with several drivers up the chain, my opinion is the set should have had a tube amp in the first place. Its a lowboy console not the upright so I have plenty of room and besides the tubes sound great driving alnico speakers anyway. The turntable works great but the auto changer is still a bit stiff, heck even the old ultrasonic remote works great for both the set and my dog.
Ready for the clincher? I recently had a lightning strike on my property of 15 acres, a tree near the house was hit and the resulting spike took out the 1N34 chroma phase detect diodes along with the horiz AFC diodes along with many other solid state things in my home. Being Germanium devices and no access to these animals I instead subbed in 6AL5s and gained a little on the chroma stability and alot in the horiz AFC stability. I can now play a VHS tape from a crummy late model VCR and not have the flag waving at the top as I did before. This thing is rock stable and even the UHF has slightly better sensitivity, Im 36 miles away from our "transmitter central" in Shoreview/Arden Hills MN and knowing where our UHF stations transmit just getting a signal where Im at is a job in itself. For those in the MPLS area KTCI-17, CW-23 and 29 all broadcast from the channel-9 tower that is located east of the twin towers along with all the FM broadcasts. The UHFs are patterned south and west of the tower with a -9db null at 40 degrees from due north. If you want more details on the stations private message me as I do alot of work for the broadcasters and know the techs.
Im going to work on getting some images of the set into the forum so you guys can see how nuts I really am. Dont know what resolution they will end up at but I will try to keep the details sharp, then I move on to my Works In A Drawer that needs the wires dressed.
Thanks again to everyone!
109
Old 09-09-2006, 01:36 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
awesome! can't wait to see those pics.
Jordan
Old 09-24-2006, 10:05 PM
ARC Tech-109
Guest
Posts: n/a
HELP!!! For the better part of a week I have been *trying* to upload pictures of my AstroSonic along with my completed Works in your Drawers but the only thing I get is the "Uploading" message until hell freezes over or I loose my connection. Ive tried 640x480 and other sizes but only with the same results? Is Audiokarma biased against Magnavox and Motorola sets? Do I need to put the original stick rectifier back into the Motorola HV section and use the 3A3 for something else? Am I loosing my mind? Anyway Im having a heck of a time here.
109
Old 09-25-2006, 06:37 AM
JCFitz JCFitz is offline
If you're using dialup you may have to send only 1 picture at a time.
Old 09-25-2006, 08:46 PM
ARC Tech-109
Guest
Posts: n/a
I keep getting "Unable to create image [/var/www/vhosts/audiokarma.org/httpdocs/gallery/uploads/16267/IMAGE031.jpg].
Please contact system administrator."
Guess it doesn't like my combo after all
Going to try something else for the time being
109
Old 09-25-2006, 09:02 PM
captainmoody's Avatar
captainmoody captainmoody is offline
Is this what your combo looks like? Love mine, Sounds like yours really performs! I prefer mine unmodified and factory original though.
Old 09-25-2006, 09:16 PM
ARC Tech-109
Guest
Posts: n/a
Looks similar to yours Moody but mine has the sliding wood doors over the CRT and is a bit wider and I'm sure heavier. I had little choice but to deviate from stock form as I couldn't find the correct output transistors for the original amplifier and the service manual shows a different stereo receiver only outlining a 30 watt version in an upright "bookcase" type cabinet. I added the stereo MTS decoder at the request of my kid and I had to agree with him, it was capable and no holes had to be drilled so returning to stock would be very easy.
Now Ive tried to upload some of my images to the users side of AO-hell but even that is biased against my magnavox so Im going to try as an attachment to this post, lets see if it works!
Ok YES it works! That is my daily watcher that started its life off in a smoke filled apartment in Bloomington MN then moved to a barn in Rogers MN where it sat for around 10 or so years then moved to my home on July 04, 06 where it will stay. I like to keep my stuff forever or at least as long as I can. The pioneer SX and Technics CD player have been owned by me since new and bought with my paper route earnings along with working at a high-end audio store during my early teen years. My motto is simple: If it works why replace it?
More pix to come as I crop them to being dial-up friendly
109
Old 09-25-2006, 09:49 PM
Yup, similar cabinet. Mine has the sliding doors as well.
Old 09-25-2006, 10:16 PM
ARC Tech-109
Guest
Posts: n/a
I looked closer at your combo and noticed the sliding doors are actually cloth covered and cover the speakers, VERY cool touch on yours.
Do you know cabinets? I have no idea what "series" mine is as far as styling is concerned. I do plan to strip and refinish the cabinet for my set as the finish now had become saturated with cigar smoke and a few water rings on the top.
Those KLH speakers in my first photo was my first attempt at a veneer job. I found those speakers sitting next to a trash can in 1987 after a storm dumped nearly 8 inches of rain in one night. They looked like bannana peels but a few weeks in my fathers wood shop he taught me the art of veneer so I plan to do walnut veneer inserts over the poplar hardwood used for the sliding doors and top panel. Dad is an expert cabinet maker among other trades and he loves doing this sort of thing.
Thanks for the look
109
Old 09-26-2006, 02:52 PM
Pioneer727's Avatar
Pioneer727 Pioneer727 is offline
SEMPER FI
I just recived a Magnavox Astro-sonic 615 for my Birthday Its in Mint shape sounds Great thu no TV just AM/FM and record player I guess its from 1965. Everything Works. Yours Is Great Looking too .
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PD-F1007 CDP
Pioneer PL-115D
JBL L46's
Dayton SUB-100 Powered Subwoofer
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 09-26-2006, 10:31 PM
ARC Tech-109
Guest
Posts: n/a
I actually like those old console stereos or HiFi's as they were known. My grandmother used to have a Magnavox but dont remember the model or series. Do know it used 6V6's in the outputs and had a turntable and seperate speaker that was similar to the main unit. I can remember her getting wild with that thing playing old Elvis, Hank Williams or whatever she could grab ahold of at the time, think I was maybe 4 or 5 years old. I do remember that thing could bark quite well.
109
Old 09-27-2006, 07:08 AM
Pioneer727's Avatar
SEMPER FI
Mine sounds Good will sound better after I replace some Caps hehe . I am trying to find a needle for the MicroMatic turntable at Needle Doctor wish me luck
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 09-27-2006, 05:08 PM
ha1156w's Avatar
ha1156w ha1156w is offline
The best way to reference the stylus is to drop the cartridge -- one screw on the underside of the tonearm. On the top should be the cartridge model number. Even if the stylus "looks" right, there are lots of nuances that will bite you in the tail for a mismatch. I know that the EV285 and EV275 they used to use are different in an eyestrainingly small ridge that makes all the difference as to whether the stylus fits or pops back out mid-record. I've had good luck finding new stylii on eBay if you can't get it through the normal channels. Also try Needle-In-A-Haystack too. They have lots of inventory last time I dealt with them.
Old 09-27-2006, 07:18 PM
Pioneer727's Avatar
SEMPER FI
I popped the cart and found Electro Voice Model 453. Sent a Email with a pic of the needle and cart model # to Garage A records and he found a model 357 thats looks just like it. I will check your link Thanks
Ron
Pioneer
SX-1050
SX-980
SX-727
Teac A-3300S
Pioneer PL-115D
JBL L46's
Sansui
G-7700
8080
x2 AU-7700
Teac 2300S
JVC QL-F4 TT
Toshiba 3850 DVD
SP-2700's
Old 10-01-2006, 01:46 AM
ARC Tech-109
Guest
Posts: n/a
More AstroSonic Pics
Just a few pics I snapped off today while cleaning up the convergance, the purity rings were getting a bit weak and purity was starting to suffer. Think it all started when I demag'd the set and went across the back with a live loop. Oh well Im far from perfect. Enjoy the pics
Sorry I didn't vacuum the floor, didn't feel like dragging out the old Kirby 508
109
