Old 08-19-2006, 03:35 PM
ManFromPorlock's Avatar
ManFromPorlock ManFromPorlock is offline
Question 26" RCA Colortrak 2000
I just picked up a 26" RCA Colortrak 2000, model FKC2022T, made in October of '84. HEAVY sucker but it seems to work. Two questions: does anyone know of a downloadable owner's manual for it, and what simple remotes will work with it? I can get an original remote on eBay but one look at that thing and my wife will retreat to the bedroom and refuse to come out. The TV's for her so I need something a little less daunting.
Being cheap isn't a character defect -- it's an art form.
Old 08-19-2006, 03:45 PM
Old 08-19-2006, 06:30 PM
jstout66 jstout66 is offline
I've got a 27" Colortrac 2000 from 1987. They are sweet sets and I think were on the high-end of the RCA model line up. Mine however has an annoying glitch. It shuts itself off on ocassion. It always switches back on, but you never know when it will shut itself off again. Sometimes it doesn't do it for weeks, and then it will "sass" several times a day.
Old 08-22-2006, 06:05 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
Ugh, my '82 Zenith System 3 does that once in a great while, but it isn't too annoying.
Old 09-04-2006, 01:06 PM
Tom_Ryan's Avatar
Tom_Ryan Tom_Ryan is offline
The RCA Selectavision line was state of the art for RCA in the early to mid '80's. I have a pair of 25" Colortrak 2000s from 1985. One set is equipped with the multiple Video inputs. Channel 99 and 98 are used to select Video 1 or Video 2 input from the rear jacks. A special infra red remote is used for home media center applications that can operate a VCR , Video Disc player, as well as the TV set all in one hand held control box. Really cool. But, One of my Colortrak sets developed a bad pin in the CRT socket over the years. I'm thinking we need to declare these Colortrak sets rare antiques because, no matter how hard I try, no one seems to be able to find a replacement socket for me.
Any clues where I can get a CRT socket or parts of one??? Let me know. Thanks.
Old 09-04-2006, 04:47 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Tom: any XL-100 set from the late 70s to the early 80s with the inline tube should have that odd socket.
Jordan
Old 03-27-2009, 05:57 AM
kudzu kudzu is offline
RCA Colortrak 2000 (Model FLR2523E) Idiosyncrasies
Hi Tom-
I also have a 25" Colortrak 2000 with a panel of 10 RCA jacks in the rear and a sticker which reads Model Number FLR2523E and Manufactured in 1985.
It's been sitting in the closet for at least six to eight years as I seem to recall having some problems with the picture cutting out or some other erratic display issue and I would have to smack the box on the side to resuscitate it. I can't remember the specifics but do have a vague recollection of wanting to get it checked out as it's been collecting dust all these years.
Fast forward to about a week ago when I got the TV out, carried it to the exit in preparation to dispose of it when I impulsively tried to hook it up to one of the DTV converter boxes which had just arrived the week before. Lo' and behold, it worked again, so I switched it out with another, early 90s TV, reconnecting it to the DTV converter box, an old stereo and a DVD player, and it has worked without the erstwhile mishaps since--the stereo sound in particular, with the additional hi-fi receiver and speakers, is fantastic for such a dinosaur.
The picture may have faded a bit, though I'm not sure as I don't have good comparison.
One sure abnormality however is that the picture does seems to have rotated ever so slightly clockwise about the center axis about a degree or two, almost as if it's starting to drop off to the right. Can you picture this and does it make any sense to you?
What might be the cause of this? Any way to make an easy adjustment?
And what else might I expect with this particular model?
You mentioned one of yours had a "bad pin in the CRT socket." What is the symptom of this and was the TV still viewable? And if so, are you using that one and the other?
One minor difference is that I select Channel 91 or Channel 92 for Video 1 or Video 2 (which I've been using for the converter box and DVD player)--you mentioned Channels 98 and 99.
This is the remote control I still use to turn it on:
http://en.wikipedia.org/wiki/Digital_Command_Center
The only other component acquired which it could operate was an RCA VCR which gave up the ghost some time ago.
Any other insights you could give about the TV would be much appreciated as I would be interested in swapping idiosyncrasy tips if it turns out you're still using them and interested in talking about them.
Finally, I suppose that as you point out that as parts are hard to acquire, that if the TV does have any problems which make it unviewable, we should just junk it?
Old 03-27-2009, 06:14 AM
On re-reading my post above, I realized I should have addressed it to anyone who might have insights into the RCA Colortrak 2000.
Thanks!
Old 03-27-2009, 11:10 PM
jlw37663 jlw37663 is offline
Originally Posted by kudzu View Post
Hi Tom-
I can relate to what you say about having to jar the set to restore reception. I have had similar experiences with two similar RCA built sets of this vintage. Both were cured of this problem by removing the tuner unit and very carefully resoldering the entire circuit board. I used a controlled temperature Weller soldering station. I have had extensive experience in such soldering and I don't recommend doing this as a first time learning experience. I later read somewhere that these sets were notorious for such problems in the tuners.
The set I have is an RCA built JCPenny 685-2502KK which is similar the RCA FKC2022 (JCP had a good sale price going) which I bought '84 or '85. The other set with the same problem was about a year newer RCA bought by my inlaws. Their tuner problem started about a year later than mine and also after about the same amount of operating time on the set (go figure).
My JCP/RCA is still operating in a semi-retired location in the bedroom using an Insignia DTV converter and produces a very good picture still (but only when using external video inputs). For years this TV has produced a much better picture using an external VCR tuner than with the internal tuner. This set seemed to gradually lose its color fidelity and sharpness on the internal tuner over a period of years. One possible explanation would be physical changes in the RF/IF transistors due to long term effects of soft x-rays on the semiconductor doping. Back in the mid 80's, another recently graduated engineer was telling me that he had learned in school of an industry concern that this (soft x-rays inside TVs) might be a problem with certain transistor fabrications then being used in RF/IF applications. He seemed to think that the characteristics would gradually change and some device junctions would eventually fail (short out in the junction).
The RCA Colortrak2000 set belonging to my inlaws worked for many years after the tuner repair and finally went off line due to a probable failure in the horizontal sweep transformer assembly. They still have the set but have declined to pursue repairs. The HOT has that freshly roasted aroma.
I still have the JCP user manual. I'll check and see if they still have the the one for the RCA. Scanning is a possibility but there isn't a lot of information in the manual.
