Old 05-04-2006, 05:25 PM
Adam's Avatar
Adam Adam is offline
video disc player (CED) problems
I finally found some discs for my CED video disc player, RCA model SFT100W. What it does is play the disc for about 30 seconds, then get stuck, move backwards for a while, then start playing it again until it gets to the same point in the disc, then get stuck and go backwards again, and do it over and over. It does this on all the discs I tried, and I tried about 10, so I don't think the problem is due to bad discs. The rewind and pause functions work, but when I try the fast foward, it moves foward for just a few seconds, then gets stuck.
I found this in the back lot of a used electronic parts store, where it had been sitting outside at the bottom of a heap of junk for probably decades. It was being rained on, as the shifting of the piles of stuff had recently exposed it. The fact that it still works this well I think speaks highly of the quality of these units. Anyway, if anyone who knows these things can point me in the right direction thanks alot. I am hoping to watch the discs on my ctc-15, as the mixture of two seldomly seen anymore devices such as these really appeals to me. Although I suppose watching it on the system 3 would be more accurate as to what these were originally watched on.
Old 05-04-2006, 06:00 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
Could be anything from a bad stylus, a bad belt or even servo probs. I replaced a stylus in a stereo model back in the 70's and seem to remember the platter and linear tracking arm being belt driven. Dang! That was nearly thirty years ago!
Old 05-04-2006, 06:20 PM
Nakdoc Nakdoc is offline
nakamichi spoken here
Dang!
Since the problem repeats, I'd blame the arm slider. Needles are cheap and available. I might even have a manual.
A stereo can work and it can play.
SOTA Sapphire, Lustre arm, AKG mc
Yamaha C85 , C1
Carver TX-11a
Kenwood L-07MmkII , Yamaha B1 + UC1
DCM Time Windows ADS 200 IMF TLS80
Revox B77 Nak 680 pioneer CLD97
Old 05-04-2006, 06:23 PM
Chad Hauris's Avatar
On several of these machines we have found the belts disintegrated and left a tarry substance all over the pulleys...cleaning with isopropyl alcohol (very messy) and new belts fixed the ones we worked on.
Chad Hauris
Old 05-04-2006, 07:13 PM
A belt goes bad and the stylus doesn't move, or doesn't move far, and so it just keeps repeating that same section. That's what happened with mine. I still don't have it right, as it skips a lot. The belts I have are not really right.
Old 05-04-2006, 07:15 PM
It sounds like the arm is getting stuck, or never moving at all. The arm is moved by a servo mechanism (like a linear tracking turntable). It could be a problem with that circuit, the motor that moves the arm, a belt, a gear, or something obstructing it. It might even be rust, or lack of lubrication.
Old 05-04-2006, 09:01 PM
Take a look at http://www.cedmagic.com/selectavision.html
Ever wonder why the CED system bombed, but DVD was successful?
Old 05-04-2006, 09:42 PM
Celt's Avatar
Peanut Head
As I recall, the SelectaVision CED failed in the marketplace for two reasons. a.) You couldn't record on it, whereas VHS/Beta units were becoming commonplace and b.) Finding CED's to buy or rent was difficult. As we all know, everybody seems to be renting or selling DVD's! Ooh! DVD discs and players are very affordable too!
Old 05-04-2006, 09:56 PM
Don't forget about Analog laser disk a better system and it bombed as well.
Old 05-04-2006, 10:01 PM
Celt's Avatar
Peanut Head
Yep...and again, price and availability...plus the average consumer wants a format they can record on. I wonder how many folks are buying DVD recorders for time shifting?
Old 05-04-2006, 10:31 PM
Believe it or not, most people aren't interested in recording. Every person I know has a DVD player, but I'm the only one who uses a VCR for recording. Most of my friends don't even have a VCR.
Old 05-04-2006, 11:50 PM
If I'm not mistaken the DVD is the most successful Electronic product ever?
And why not, fantastic picture, compact size, staggering amount of product available at cheap prices.
Did anyone ever dream they would be able to own entire seasons or entire runs of their favorite shows in a format no bigger than a small book!
Old 05-05-2006, 12:02 AM
john_w's Avatar
john_w john_w is offline
Miscreant
I had a player that would skip back on occasion and basically acted like the disc itself had scratches or crud on it. But all my discs were doing that - never made it thru a single disc. It turned out to be a worn out motor, so unfortunately in that case, it was destined for the scrap heap. I hope yours turns out better.
BTW, I later picked up a nice Pioneer LD player that is also a 5 CD changer. (Shweeeeeet!! ) I have yet to see a single skip out of it.
Old 05-05-2006, 01:27 AM
Celt's Avatar
Peanut Head
I just realized something about my "time shifting" question. Around here, if you pay the extra bucks for digital cable, you automatically get a HD recorder that's part of the digital tuner they supply you with. But I digress... Wish you luck with your CED player Adam!
Old 05-05-2006, 02:02 AM
kx250rider's Avatar
REAL TVs have TUBES!
BELT!!! Been there, done that. Also, be sure to clean out all the old hardened lube, and put some new white grease on the sliding surfaces.
Charles
