need rca tripler
i need a tripler actually 2 used in the ctc91 & ctc92 series
rca part # 145718 [ generic replacements] will not work because they do not have a internal dc return. they will produce high voltage but you get no picture. thanks steve |
Tripler for rca ctc91 or92
Hello--this is Jack i MAY have a chassis with that tripler on it, maybe more than one. If you don't mind a used one, give ne a few days, to check my junk, and i'll see what i can find.
re triplers
used ones will be fine with me. thanks a bunch. i depleted my inventory of used ones. these will be used in the sets i am going to keep. thanks steve
need tripler
Right now, on e-bay, there are SEVERAL mdr regulator modules for sale. ,used in your ctc91 and 92 sets. you might want to look int these. i DO NOT have any sets that need them.
modules
hi i have plenty of the mdr modules but no triplers. thankss steve
| Audiokarma |
Did you find a tripler?
I have a 145719 and 146356 . I dont know what the differences are maybe different DC B+ voltages. Doug |
triplers
what do you want for them i will try them. thanks steve
I'll see if I can come up with a little more info on these.
Are you sure both the ctc91 and 92 used the same tripler? the 145719 on the tripler itself has 1466860-3p and MH980A05 Doug |
tripler
both chassis will work with the sams tripler... steve
I was looking a an old ECG book and the difference ecg shows is the 145718/ECG533 has a 1.5meg internal focus resistor and the one I have 145719/ECG537 has a internal 4.7meg resistor. You may not get it to focus with the 145719.
Both of the above are a 5 step tripler. The 146356 is a 6step. I don't think you will get either one to work correctly in your unit. But if you want to buy them $20 each both are new ,never solder on in RCA boxes. If you need any other parts contact me I closed my shop in 2000 after 25 years along with parts /schematics from my own and from buy outs of other shops plus from my dads shop 1950- up. Also might keep in mind on the following web site has old RCA parts http://www.fouraker.com/. Excell distributing in Cincinnati has old parts. Its possible I may have other triplers in unsorted boxes, will look when I get a chance. Doug |
| Audiokarma |
I found a site with your 145718. I must be selling mine too cheap.
http://www.partsolver.com/Product.as...tutePart=False OUCH! Doug |
