curbside Telefunken
Hey guys, look what I found in the garbage last night. It doesn't work, but maybe one of you knows something about it and could possibly fix it!
Very cool. Looks like it is Sw as well.
I'd love something like that, but I never seem to have the luck.. |
Achtung! Izzen a modelnuumber onnit? Iv zo, get der schematic hear:
http://www.nrhf.no/nrhf-bank-eng.html Mike Koste Gobs of Knobs Ambler, PA |
Is it a battery and ac set? Looks as though that green thing is a battery.
If its got an AC cord too, its probably just in need of some power supply work. Alot of these portables had selenium rectifiers in them. I had an admiral portable with a similar setup. Replace the selenium rectifier with either a bridge rectifier or a diode and a dropping resistor, then power up and see what happens. Do the tubes at least light?
Jordan |
| Audiokarma |
I plugged it in last night, the tubes don't light up, but there wasn't any smoke or smell. If there's anyone in the NY area that may be able to fix this, please let me know. Also, this is both plug-in AND battery.
This is a pretty rare type of radio - a tube battery portable with FM - I've never seen one. A little more info here: http://www.radiomuseum.org/r/telefunken_bajazzo_56.html
It may be designed for 240 volts AC...a lot of the time though there is a voltage change switch for U.S. use.
heinz preiss: http://www.angelfire.com/biz/grundig/ doug s. |
| Audiokarma |
If you send it off for repairs you may want to remove the chassis from the cabinet and just send the chassis as that way you won't risk the case being broken.
Bazzaro Fixin
Give Mr. Mike Simes a call. He's on Long Island and his number is 516-223-1470. Good luck with the set........
