Old 08-03-2005, 01:38 PM
Jonathan Jonathan is offline
This a 630TS clone or a 621TS clone?
http://cgi.ebay.com/TELETONE-7-INCH-...QQcmdZViewItem
Item number: 6198384158
Jonathan
Old 08-03-2005, 01:47 PM
pronostalgia
Guest
Posts: n/a
No,the only connection between this set and the 2 RCA's you mentioned are the knobs. The 621 and 630 use magnetic deflection and this set uses electrostatic deflection so that circuitry would be almost totally different.
Old 08-03-2005, 01:52 PM
I thought the 621 used electrostatic deflection?
Old 08-03-2005, 02:11 PM
David Roper's Avatar
console lover
Noop!
tvontheporch.com
Old 08-03-2005, 02:18 PM
The Teletone uses a 7JP4 CRT.
It's closer to a Motorola VT-71 than a 621 0r 630.
Old 08-04-2005, 12:17 AM
Ahhh, I see now.
Thanks.
