Old 03-28-2005, 08:47 PM
Whirled One's Avatar
Early Portacolor dumpster find
Funny, I've "rescued" two PortaColors from the trash in the past two months... The first was a later 10HE chassis from ~1976 in really *terrible* shape; it will probably end up as a parts set for my other PortaColors. While I've already got about four later-version Portacolors, I'd been keeping an eye out for an early one for a while. Well, a bit ago I found another one sitting forlorn and lonely on the ground by a dumpster full of trash... Poor lil' fella.
Turns out it's certainly an early PortaColor at that-- it's in fact the very same model (M213BWD) that Consumer Reports reviewed in their article (published in Feb. 1966) on this first portable color TV.
Overall, it's in fair-to-okay condition. The vinyl(?) fake wood finish is worn and peeling from the cabinet in many spots, and the front facia is a bit scratched up, but at least all the knobs are present, and (most amazing) the original antenna rods are still intact..! (those always seem to be broken on these things) I checked the chassis for obvious problems and cleaned it up a tad, then tried soft-starting it, and lo-and-behold, the darn thing works!
As others here have mentioned before, old GE TVs tend to be rather a mixed bag in terms of reliablity, but for whatever reason those Portacolors seem to be the equivalent of the Energizer bunny-- they just keep going and going and going... Seems like almost all of them that I've encounted either functioned okay, or had what appeared to be fairly simple problems.
One thing I found odd about this set though-- this is the only 60's-era PortaColor I've ever seen that didn't actually have the identifying term "Porta-Color" anywhere on the set; the name plate on the front just says "GENERAL ELECTRIC Color" (with "Color" in the same style script as in the "Porta-Color" logos. While I know GE referred to this TV design as the "PortaColor / Porta-Color" from the very beginning, perhaps they didn't start actually using that name on the sets' nameplates at first..?
One other thing-- I can confirm CU's observation about the relatively coarse dot pitch of this set. The 11SP22 picture tube used in this set is definitely coarser than the later dot-phosphor CRT that GE started using a year or so afterwards. However, it's still probably about equal in resolution to the stripe-mask CRT that GE started using in the 70's.
