Old 03-09-2005, 09:10 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Alternate picture tube for a 310GUB4?
My tester/rejuvenator book doesn't list that model.....is there any other that interchanges?
It's out of a small mid-seventies Quasar B/W portable.
Old 03-10-2005, 03:22 AM
kc8adu's Avatar
kc8adu kc8adu is offline
likely a common baseing.
if it is a 7 pin it is standard.
what tester do you have?
email for more info
Old 03-10-2005, 07:23 AM
Kamakiri's Avatar
B&K. If I knew the filament voltage I might be able to work with that.
Old 03-10-2005, 08:56 AM
kc8adu's Avatar
panasonic who made that set had some oddball low voltage heaters in some tubes.
99% of others are 12v@150ma
some of these tubes need the high g2 setting on my 467 to set cutoff.
btw i can find you a good tube as i keep some around for the cnc guys.
email for more info
Old 03-10-2005, 10:06 AM
Kamakiri's Avatar
To be honest this set's probably not worth that. I just wanted to see if I could brighten up the tube by cooking it for a little while on the activate mode. If I can, then it will go into use in my camper
If not, it goes in the can.
Old 03-10-2005, 04:06 PM
kc8adu's Avatar
if that doesnt do it the lightest tap possible on the rejuvenate button as a last resort.gotta be carefull to not strip the cathode.
i have shot a few oddballs to get a machine rnuning long enough to order a tube.sometimes they look like new.
hey you get some cheap practice.
email for more info
Old 03-11-2005, 01:15 AM
prewtv's Avatar
prewtv prewtv is offline
Dennis
In the sencore book, fil on 3+4, k on 2, g1 on 5, g2 on 6, fil 12.6 volts,
g1 neg bias 52 volts, no other info in book
Old 03-11-2005, 01:26 AM
prewtv's Avatar
Dennis
In Philips book it adds fil = 12 volts at .067 amp, 12KV on anode, 110 volts on g2, and that it has mounting lugs.
Old 03-11-2005, 09:03 AM
kc8adu's Avatar
that confirms what i thought.
standard pinout.
seems i fixed one of those sets a while back for a 70's nut.was in a bright green case with a gaudy chrome quazar logo.
had a dead tube and i remember replacing it with a generic p4 monitor tube i stock for cnc gear.
email for more info
