Looking for Small color Tube Socket Pin out
I'm trying to fix the plugs on my Beltron. I found out which wire is which in the harness coming from the tester. The small 14-pin test plug has a lot of the wires either removed or cut off. If I could find out where the heater is and all the other connections on the pinout I can put it back together. I don't have any tubes handy with the small connector and couldn't look up one to find out what it is.
Hi to all,
Hi Aperna1985, This site gives CRT pinouts (B&W and color) by type and brands : https://crtdatabase.com/tubes https://crtdatabase.com/ search : https://crtdatabase.com/search This 135 page 17,5Mb database gives the pinouts and setups for the Sencore CR-70 "Beam Builder" & CR-7000 CRT testers : https://forum.retrotechnique.org/upl...PUdOIhECm6.pdf Another interesting CRT pinout site : https://web.archive.org/web/20060926...faq.htm#crtpin Main article : https://web.archive.org/web/20060926...faq.htm#crtcsa Hope all this helps you find your 14 pin socket setup, Best Regards jhalphen Paris/France Last edited by jhalphen; 11-18-2024 at 04:29 AM. |
