Old 05-26-2024, 08:41 AM
maxhifi's Avatar
maxhifi maxhifi is offline
Align sound and picture fine tuning
Haven't worked on a TV in a while. One thing I can't seem to remember is how to adjust a TV so that the picture sharpness and lack of buzz in the audio peak at the same point of adjustment of the fine tuning control. Is this trivial or does it require a full alignment? Can't seem to find any reference to this adjustment in my TV books, maybe haven't looked hard enough.
Old 05-26-2024, 10:27 AM
It depends on the set. There were split carrier sound and inter-carrier sound sets. Split sound sets you fine tune for best audio and best picture should match that. Inter-carrier sets (sound splits after the video detector) you tune for best picture and sound should automatically be good.
On split-carrier sets if sound and picture don't line up you need to give the set a full alignment.... At least that's the "proper way". I've found if the video alignment is good enough to get a fairly perfect picture with a Philips PM5544 test pattern I can usually walk the sound alignment by ear to a state where the set works as good as you'd expect a new set to...All split sound sets are the old 21MHz IF and I don't have alignment gear for that frequency so the "proper way" isn't an option for me.
Inter-carrier sets you can align the sound as needed without touching anything else and it will be fine and proper.
Old 05-26-2024, 12:28 PM
maxhifi's Avatar
Hey thanks for the excellent summary! Looks like mine is inter-carrier, here's a snippet of the schematic.
File Type: jpg Screenshot_20240526-095930_Gallery_copy_800x360.jpg (50.3 KB, 12 views)
