Old 04-16-2024, 07:39 PM
GidTanner GidTanner is offline
Admiral C330A Black and White TV
Does anyone know where I can get any info on this set (schematic, photofact), any pertinent information on it? It's a 218511A Chassis Number and 11323983 serial number. It has a 23" screen. Thanks in advance.
Old 04-16-2024, 08:35 PM
damen's Avatar
damen damen is offline
Is this a Canadian set? Sams Photofact set number 581, folder number 1, lists model numbers C329, and C331, skipping C330. That Photofact lists chassis numbers as 20A8, 20B8, and 20UA8 ,nothing like the numbers you list.Photofact set number 686, folder number 1 shows model number C3301 which looks more like your set with chassis number 21B5-11C. The chassis numbers are usually ink stamped on the chassis apron.
Old 04-16-2024, 08:47 PM
Thank you, I'll look into it. I can't tell you whether it is Canadian or not-no idea. I will check it out, and thank you.
Old 04-17-2024, 12:35 AM
Beitman TV-21 / 1963 (available free at WorldRadioHistory.com) has the C33_ series models - look up the tube complement of your set and compare to the chassis in the Beitmans.
USN RET 22YRS (Avionics/Cal)
Old 04-17-2024, 03:01 AM
ronl ronl is offline
If it Is Canadian,it should be marked somewhere.if so,I might have the info for free. RonL
Source of free vintage Canadian tv service info.Caretaker of various 1920 to 70s radios,a Farnsworth 651p tv,a RCA Ctc5 and a few 50s tvs.
Old 04-17-2024, 08:43 AM
Canadian would have there FCC markings on the back ( whatever its called)
instead of our FCC. Looks early 60's so any Admiral console info
should be usable. They were good sets. Chassis ## should be short number-letter combo like H-10 etc.
Zeno
