Old 03-21-2024, 04:46 PM
Lain94's Avatar
Lain94 Lain94 is offline
1969 Zenith Chromacolor TV NOS!
This was a rare find for me. A sealed New in the box 1969 Zenith Chromacolor portable tabletop tube tv. It uses the well known 14DC15 chassis. Technically a hybrid set. Also what is remarkable about this tv is that it actually uses a integrated circuit chip which is very high tech back then. I purchased this tv on facebook marketplace awhile back. It was a big pain to have shipped but arrived to me safe and sound. A liquidation company had not one but three of these chromacolor sets new in the box and all of them used the 14DC15 chassis. I debated on whether to open the box and inspect further and decided to do so since it seemed silly to never open it. I slowly brought up the tv with a variac with success! Virtually no adjusting at all needed as it was setup from the factory and was amazingly having no issues at all other than some arcing or high voltage buzzing at first during warm up but this stopped after a bit of time. Absolutely amazing condition and very impressed by it. I am inclined to recap regardless, what do you all think I should do about this unique situation?
https://imgur.com/a/x2k1Lfj
For those of you who are on tiktok, I have a channel that has a few videos of this tv in operation:
https://www.tiktok.com/@noahdawson44...44818129390891
Old 03-21-2024, 10:21 PM
dishdude's Avatar
dishdude dishdude is offline
That's beautiful.
Old 03-22-2024, 05:42 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi Lain94,
What a find! stored for 54 years and works perfectly straight out of the box, rare indeed.
Will be interesting to follow what our Zenith experts advise in terms of preventive maintenance or just leave it alone & power-up from time to time.
Best Regards
jhalphen
Paris/France
File Type: jpeg F6B54286-E76D-4082-BA53-4ED6768F86FD.jpeg (82.4 KB, 57 views)
File Type: jpeg 370E19F0-F9FF-4612-B2EC-B96A61D0BD53.jpeg (95.0 KB, 40 views)
Old 03-22-2024, 07:52 AM
consoleguy67 consoleguy67 is offline
60s Throwback
One of the best!!
Old 03-22-2024, 08:54 AM
Nice catch ! Its not a '69 though. Its a D line sets so
late '72 to late 73.
Zeno
Old 03-23-2024, 02:34 PM
Lain94's Avatar
Zeno
Yeah I think so the more I look at the inside because an IC chip in 1969 would just be way way too early.
Old 03-23-2024, 05:09 PM
Actually Zenith used its first IC in the 69 model year (1968) for
color demodulation. Also added AFT that year. One of those long legged
metal case OP amp styles. Plugged into a tube socket. IIRC youurs
uses a DIP IC & plugs into a socket with hand wiring provision.
Zeno
Old 03-23-2024, 06:22 PM
Zeno
+1
In 1971 some of the consoles got a duramodule with a dip IC. And in 72 some of the consoles with the round IC that plugged into a standard tube socket switched from that to a chassis socketed DIP IC (that's the only difference I noticed between the 20BC50 and 20CC50 chassis). It seemed in the hybrid era Zenith fielded more different color chassis both console and portable than they did before and each was slightly different how it was a hybrid....My guess is that Zenith was afraid that they'd get a bad batch of parts, or someone would make a bad circuit and that if they didn't have that technological variety their whole brand would suffer instead of only a small portion of their line.
Old 03-23-2024, 08:11 PM
+1
Zenith chassii evolution is interesting to me. They are almost all the same.
Best example is 4 tube hybrid, flat chassis then CC2's. All the same sets
with many of the same parts & service problems. Just changes in the
sweep for the most part. If you can fix a CC2 you can for the most
part do them all.
The 14 & 16" were more built to size & not quite the same sets.
You cant squeeze a flat chassis into a 14" set !! In later yrs they did
get a CC2 into a 13" set complete with a massive power transformer
( 13GC10 ) And did it again getting the XXX A.K.A. System 3 style
chassis a 13 ". And both retained easy serviceability.
enuf fer now !
Zeno
Old 06-23-2024, 04:34 PM
Lain94's Avatar
Bad news: CRT stopped working no raster at all, no signs of life from CRT anymore nor any high pitch coil whine from flyback indicating HV voltage problems of some sort. puff of smoke and electrical burning smell. I quickly turned tv off as soon as it occurred on power up. Sound still worked just fine however. Likely a capacitor failed will be opening up set to examine what burned/smoked up soon and will probably start checking all the capacitors closer.
Old 06-23-2024, 05:05 PM
Look for a square black fuse near the h out tube.
Its a Bell fuse & marked 500-1 ( socketed) or 500-1p (solder in)
500 means 500 ma.
It may be all it needs.
Zeno
