help for Trinitron kv-m1430a Dead
Hello everyone, a month ago the Trinitron kv-m1430a suddenly died, I use it to connect my old video game consoles, it has turned off and no longer shows signs of life, in fact the red standby LED is also off. 'I opened to try to understand what had happened to him and on sight there is nothing burnt, I started to do some measurements and first started from the fuse and it is ok, then I got to the 400 V 220 uf electrolytic capacitor and until there the voltages are present, then I went up to pin 3 of the transformer and they arrive 323 Volts, then to C 609 and from the diagram there should be 120 Volts but I can not find anything,
then I went to measure the voltages on the STR54041 which should be a voltage regulator and the measurements I made are all wrong, from what the diagram tells me. Str54041 1: -17.2V 2: -17.2V 3: 187 V 4: -17.5V 5: -17.5 After various checks I managed to find a shorted component, D611 a zener R2M, I disassembled it, I gave voltage for a second and I saw that the TV led turned on, then I ordered a new R2M and replaced it , as soon as I switched on and blew the diode again. So I thought it might be the STR54041, I ordered the STR, I mounted it and just turned it on and immediately blew the 4 Amps main fuse, yesterday I reassembled the old STR and the original shorted diode to see if anything happened, as soon as I given voltage and jumped R601 from 3.3 ohm. I don't know what to do anymore, it's getting bad.😔 this is the electrical diagram
Be sure you are using the right ground. There is a hot ground
in primary & cold ground for secondary voltages. If you can put up the power supply schematic alone I may be able to help more, its to small to read. 73 Zeno ![]() LFOD ! |
This scheme should be more detailed https://drive.google.com/file/d/1BPc...ew?usp=sharing Service manual https://drive.google.com/file/d/1RHf...ew?usp=sharing |
Use the neg end of bridge for ground. It looks like they used cold ground
for the voltages ! R601 just to limit inrush current while big filter cap charges. First be sure there are no shorts on the 3 secondaries The 120 V is most likely. R602 & R607 give IC a kick start. If you dont get neg feedback to that pin IC will blow. Open resistors will give "dead set" R609 & R628 are the low end ( E ) of the IC's output. Over current will be seen here if a short on chassis & shut down the IC. If IC isnt blowing you can monitor to see if IC is trying to start etc. Unplug the DGS coil so it wont confuse you. Let us know how you do ! good luck Zeno LFOD ! |
Tomorrow I'll check what you said, then I'll let you know .
| Audiokarma |
I can'taking measurements , every time I give voltage, it burns R601. I measured R602, R607, R609, R628 and they are all ok, I also checked all the diodes on the power supply and they are all ok
I isolated the three outputs of the secondary to measure the impedances of the transformer, it gave me very low values 18 - 14 = 1.9 Ohm 4 -8 = 0.5 Ohm 2 - 12 = 0.5 Ohm not so if these values are useful. I have isolated all the outputs of the transformer T601, I have unsoldered D604 C608 C609 R612 R613 T604 and D611 but R601 keeps breaking as soon as I give voltage Last edited by bigboss80; 02-21-2022 at 11:48 AM. |
Hope you have a variac.
Unsolder pin 3 of the IC. Jump resistor & turn up slow from 0 VAC & watch the current. Next would be unload one at a time the caps & semis off pins 3 & 7 of the transformer one at a time using variac as above. I never had a switch mode transformer go bad BTW. try that Zeno |
Hi, thank you, unfortunately I don't have a Variac. This afternoon I tried to unsolder SRT54041 and giving voltage R601 did not jump, could it be STR that causes the short and makes R601 jump?
I forgot to add that I do the tests on the tv with the Degauss coil disconnected from the circuit |
Yes STR's do dead short. You can put an apx 75 watt incandescent
across the resistor. If its bright you have a short if dim no short. It MAY blow the main fuse if shorted. |
hi, i did as you told me, light bulb turns on, I tried unsoldering STR and light bulb does not turn on .
I think STR is the problem, I ordered a new one , New old stock |
| Audiokarma |
While the STR is out its a good time to recheck everything in the primary.
When you change it leave in the bulb & see what happens. If something caused the STR to short that should keep the new one from blowing HOPEFULLY ! Watch the caps. Sometimes they get a small crack but dont show a short. Zeno |
ok thank you, I'll do as you told me, as soon as SRT arrives I'll let you know .
We hope that the problem will be solved . |
Hello, the resistor has arrived, I did as you advised, I put the lamp on and unfortunately the problem persists, as soon as I turn on the lamp it flashes and you hear a small noise coming from the circuit with each flash, after a while the flashing stops and the lamp stays on, I checked D611 and R601 and they didn't jump, I don't know where to hit anymore.
https://youtu.be/di-S3QNFhsM PS: the noise is not that loud it is the phone's camera that amplifies it. |
We are getting to the place that I cant help much more remotely.
So I will give you a few more ideas. Try to turn on a few times. Then feel the IC & Q802 ( hoz out ) They should be cool. You could also check the mains current, I would guess it should be about 1 amp with DGS unplugged. The light blinking looks like the supply is trying to run but sees over current & shuts down. After that it tries to run again etc-etc-etc. Over current is almost always from the Hoz out or HV. 73 Zeno ![]() LFOD ! |
Today, I picked up the TV again after I had parked it for a while, I put the 60w bulb back in place of the fuse and I switched on, the bulb flashed and at the same time you could hear a ticking coming from the STR area, I approached and they felt like small electric discharges, I turned off I removed the latch and I moved the STR away from the heatsink and you will not believe it but the short was caused by the heatsink in contact with the STR, (I do not understand why it makes contact, I also put the fiberglass plate between the STR and the heat sink and the thermal paste for processors back on the STR before reassembling it) in fact as soon as I restored the voltage nothing jumped and the red standby light also turned on, I have to turn on the remote control but as soon as I try to turn on the red led goes out and the tube does not show signs, there must be some other problem caused by the first time I turned it on without the diode D611, I just don't know what, here any advice? Last edited by bigboss80; 04-08-2022 at 05:43 PM. |
| Audiokarma |
