Rca ctc 11a
Hi All
I've starting looking over my CTC 11A, hoping to get some help with parts. My green and red SCR pot shafts are broken off. Also the Kine Bias pot shaft is sheared. Does anyone know of a source for these twist mount type pots? Values are 1 meg for the color pots, 500 k for the bias. Also, my back cover is in bad shape. The back cover that protects the crt electron gun is missing. Anyone by chance have a decent rear cover? Thank you.
Tube audio guy. Tube collector. Last edited by dsndblm; 10-29-2020 at 12:08 PM. |
The part numbers you need are 105205 for both screen controls and 109469 for kine bias.
RCA parts I usually order from Moyer electronic supply, it will save time over trying to find one in my pile of dubiously-valuable salvaged pots. The back cover may fit from a CTC10, 9 or 7. Any with the vertical mounted chassis.
"When resistors increase in value, they're worthless" -Dave G |
Tube audio guy. Tube collector. |
Moyer had all three pots in stock, they are on their way to AZ. I had a good talk with a very nice guy named Bill at Moyer. Thanks for the recommendation.
