Zenith 5-S-228
After years of looking, I finally found one of these black dial Zeniths. Its missing two knobs and has a replacement power transformer. The speaker has many tears but should be easy to repair. I already replaced 4 wax caps but have to order the rest, also, the on off volume control is completely frozen and no matter what I try, it will not budge. If anyone has a working control, I’ll be interested in buying it. Riders says it’s 400,000 ohm and the zenith part number is 63-565, if that helps at all.
Your good times will bring me down Last edited by LADR; 05-20-2019 at 03:02 PM. |
I'll check later today and if so, I'll check the condition and PM you. The power transformer was replaced in the chassis as well. Dave. |
Nice looking radio. Probably sounds good too.
Rick (Sparks) Ethridge |
Ok. That sounds good
Your good times will bring me down |
| Audiokarma |
The chassis I have had a universal replacement control in it.
The control has a 2&3/16" shaft length. It's a 500K pot with a spst switch so it should be close. See if you can shoot some contact cleaner in your pot to loosen the binding. It looks like your chassis was stored in a damp area, where the control seized because of unlike metals used in the assembly. You might have to dissemble the control. Try that first!
Never understood where they got the idea that a K should represent 1,000 when M is 1,000 in Roman Numerals (so really the way Zenith did their schematics back then made perfectly good sense in my opinion). |
That model must've been a real problem with power transformers and volume controls.
Sure looks like it. I’m getting a control from a local friend.
| Audiokarma |
Of course they would do that, anything to try and get us Americans off the Imperial Measurement System and into Metric. |
The firm I worked at, bought a new machining center built like 10 miles away from the plant, that was all Metric. I, inquired as to the reason and the service rep said that the US government bought a lot of their machinery. ![]() When this Metric conversion died down, the firm bought another machine three years later, it was all SAE. |
