Old 04-08-2019, 04:56 PM
Palinurus Palinurus is offline
Sencore CR161 CRT Tester Socket Adapter #9
I've got a Sencore CR161 CRT Tester that is missing the number 9 adapter. I'm considering making my own. Does anyone know where to access the pin diagram for that particular socket? Thanks.
Old 04-09-2019, 09:53 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
You should be able to figure it out using the pinout of a CRT that calls for that adapter....
Old 04-09-2019, 08:48 PM
Thanks. I've got a socket (new old stock) with the twelve color-coated wires sticking out of it. Is it just a matter of identifying which ones have to be connected to the adapter pins? I looked inside one of the adapters and saw that the wires are crisscrossed. Does it matter which pin a particular wire goes in? Just being cautious.
