Magnavox VR8415Sl01 av out?
No problem with coaxial output but I want to use rca jacks. How do I switch to them. Obviously for this 84 model, there's no menu and I don't see a switch.
Genesis does what Nintendon't |
Do you have the a/v in and out jacks on the back? Just plug your a/v cable in the out jacks then in to the a/v in jacks on your viewing device. Don't need a menu for that even on menu driven decks. All the best, Tom.J p.s. If that doesn't work then there is a fault in the machine.
I've had the same problems with beta and vhs units. I noticed the new flat screen television don't seem to be able to detect direct analog signals from the older equipment . I've had to use the RF/ coaxial mode to watch videos on equipment from the 80's. Also some tapes won't play in one machine but will work in another.
Ed |
| Audiokarma |
You probably need a TBC to make the AV out signal clean enough for the new stuff to sync to/recognize it.
Pac Attack, I have the Panasonic version of your VCR and there is a switch on the front of the machine behind a flip-down panel that allows you to switch between tuner and A/V Input mode you have to switch that switch from tuner mode to A/V mode in order to be able to use the A/V inputs on the back of the VCR. I hope this helps!
-Levi |
No switch on this one. A few buttons behind the door. Nothing else.
Genesis does what Nintendon't Last edited by pac.attack76; 04-19-2024 at 10:19 AM. |
Huh, that's weird because my Panasonic VCR that's like your has a switch on the front for switching between the tuner and the A/V jacks on the back. Although now come to think of it I know there were a couple of 1980s vintage Panasonic and Quasar VCRs that would just activate the A/V inputs by just simply plugging in the A/V source into the A/V input jacks on the back and no switches were needed, that might be the way your VCR is.
| Audiokarma |
Went directly into av in on my plasma set and was working at the same time as the coaxial. I must have had it in the wrong jack on my avr. Then again, it probably doesn't work that way since I'm using hdmi out from the receiver.
Every VCR I've ever seen the A/V outs are always on. Some older VCRs do not have a tuner/aux switch, so as soon as you plug something into the RCA inputs they disable the tuner and switch over to the aux input.
