Old 07-21-2016, 09:03 PM
zenith2134's Avatar
Little Curtis Mathes
Anyone have any idea who built this little guy? I'd say it is an 11" screen and is made in Japan. Quite a good performer; had a vert linearity issue which a proper set-up fixed. CRT is razor sharp and extremely bright. I want to say this is a Hitachi but am not sure.
Old 07-21-2016, 09:05 PM
lnx64's Avatar
lnx64 lnx64 is offline
"Invalid Attachment specified. If you followed a valid link, please notify the administrator"
Old 07-21-2016, 09:07 PM
zenith2134's Avatar
fixed..
Old 07-21-2016, 10:17 PM
I tend to go by the makers marks on the transformers, CRT, caps, etc.....If alot of them say Sanyo I assume Sanyo, if Hitatchi then Hitatchi, and so on....They did buy eachother's parts, but usually they tried to keep as much in-house or through parts only vendors as feasible.
Old 07-21-2016, 10:41 PM
NEC seemed to make a lot of CM's products. I have a small CM 13" color portable that is built by NEC.
Old 07-22-2016, 05:42 AM
consoleguy67 consoleguy67 is offline
60s Throwback
Certainly not CM. It would be an 11" set in a 6' cabinet!!
Old 07-22-2016, 09:08 AM
Either chassis photos or a model number will tell
the story. Since they did so much with NEC in the
70's that would be my guess....
Old 07-24-2016, 07:37 PM
zenith2134's Avatar
You'd date this to the seventies and not sixties huh? It is NEC all the way you were right; popped the back cover off.
Had a few guests over and everyone was impressed at its pix quality
