Old 05-13-2016, 11:01 PM
lnx64's Avatar
lnx64 lnx64 is offline
Built a SDR
Decided to build an SDR tonight, based off the vulnerable RTL-2832, and sought to built it the most reliably possible, and keep it completely shielded from outside noise.
So I built this box. I ended up using a DSUB for the USB connection because I was not satisfied with USB connectors, keeping RF out (except through the F-type input).
As you can see from the screenshot, noise level is extremely low, almost completely flat. Signal is strong.
It has two operating modes, standard, for 24 – 1766 MHz. And "direct" for 0-14.4MHz (though not as sensitive / also through modded drivers).
I'm quite happy with this little box. It took me a better part of my night to do it though, and many beers, getting the grounding right. But alas, here we are!
http://i.imgur.com/EBBVglL.jpg
http://i.imgur.com/dvcVNhB.jpg
http://i.imgur.com/MfUa0qk.jpg
http://i.imgur.com/vngNq38.jpg
Without Antenna (To show how shielded the SDR is):
http://i.imgur.com/DO4ytSW.png
With Antenna:
http://i.imgur.com/XvaJ0yF.png
