Old 05-11-2016, 09:37 AM
pac.attack76's Avatar
Stuck in the past
vcr cap voltage differences matter?
Changing caps in the power supply section of a vcr. Original is 330uf 18v. I found 330uf 25v. Will these work?
Genesis does what Nintendon't
Old 05-11-2016, 10:30 AM
Yes, Higher voltage is okay.
Old 05-11-2016, 11:02 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Make sure you use low ESR caps in a switching mode power supply, or you will likely have early failure.
Old 05-11-2016, 10:13 PM
Stuck in the past
Thanks guys, yes they are low esr.
