Old 04-07-2016, 10:19 AM
Damnation Damnation is offline
Panasonic DMP-UB900 4K UltraHD Sizzle Reel
https://www.youtube.com/watch?v=NxrsaWqDVIs
4K High-Precision Chroma Processor
The UB900 incorporates a newly developed 4K-ready engine, called the 4K High-Precision Chroma Processor. By using an original high-accuracy multi-tap process to interpolate the decoded 4K (4:2:0) signals of Ultra HD Blu-ray content to 4K (4:4:4), it delivers beautiful, natural pictures with lifelike depth and vivid colors. The UB900 also has an original 4K Direct Chroma Up-scaling function so that it can deliver 4K-quality pictures with high resolution and beautiful colours from 2K content.
* A 4K/60p/4:4:4-compatible TV must be connected with an 18-Gbps-compatible high-speed cable. When reproducing Ultra HD Blu-ray content, 4:4:4/36-bit data is output for 4K/24p, and 4:2:2/36-bit data is output for 4K/60p.
THX Certified*
The THX®-certified UB900 Ultra HD Blu-ray Player reproduces the finely nuanced colours and rich, detailed images required to reproduce precisely the filmmaker's intentions. It also achieves truly lifelike surround sound. Users can watch movies at home with essentially the same quality they enjoy at a commercial cinema.
* THX is a trademark of THX Ltd., registered in the United States and other jurisdictions. All rights reserved.
High Quality Sound: High-quality audio signal processing achieves premium, wide-ranging sound
Audio/Video Isolated Twin HDMI & 7.1-Channel Analogue Audio Output
The UB900 comes with a wide range of digital and analogue terminals to suit a diversity of users' system environments. The new twin HDMI arrangement separates audio and video signals to suppress unwanted noise and achieve high-quality audio reproduction. In addition, it supports analogue 7.1-channel audio for a direct connection to a home theatre system for lifelike surround sound. Each terminal is gold-plated to resist oxidization and maintain high signal conductivity.
Carefully Selected High-Quality Audio Parts
The UB900 uses many high-quality audio parts equivalent to those found in hi-fi audio products. Large-capacity electrolytic capacitors ensure a stable power supply and provide the sound with incredible power, while a Mica capacitor reduces internal digital noise from the power line. Digital circuitry features a LAN Common Mode Filter that decreases noise from external devices during network playback, and the audio circuitry supports high-resolution 192-kHz/32-bit Audio DAC. Essentially every part of the UB900 is designed to deliver high sound quality, from signal processing to audio device output.
High-Resolution Audio Format
The UB900 is designed for high-resolution audio reproduction. In addition to conventional WAV/FLAC/MP3/AAC/WMA formats, DSD (5.6 MHz/2.8 MHz) and ALAC music files can be reproduced. Simply connect to a home audio system to enjoy music sources equivalent to studio master sound quality.
Digital Tube Sound with Up-sampling
The distinctive, warm, comforting sound characteristics of tube amplifiers are faithfully simulated. Six different kinds of sounds from vacuum tubes with 96-kHz/192-kHz Up-sampling can be enjoyed in exceptionally high quality.
4K Video / JPEG Playback
Users can also reproduce 4K videos (MP4) that they've taken with a camera or camcorder. And they can output JPEG data in 4K resolution. This makes it possible to enjoy the memories of vacation trips in all their natural beauty, from magnificent landscapes to precious images of family and friends.
DLNA
Users can freely share content, such as photos, videos and music, with other connected devices throughout the home. Every member of the family can enjoy the content they want, in their own style, regardless of time and place.
3D Glass Cut Design, Dot-matrix Display
The simple and stylish design of the UB900 matches any flat-panel TV. The mirrored front panel features a bevel cut finish on all four sides to present a subtle yet distinctive presence enhanced by the use of a high-quality dot-matrix display.
Remote Control with Backlit Buttons
The UB900’s remote control carries backlighting to allow easy operation even in a dark room - perfect for home theatre systems. Also a great touch for dark room environments is the remote’s Dimmer button, which automatically adjusts the brightness of the player’s display to match the amount of ambient light.
