Old 03-29-2016, 05:34 PM
1986 Sears color
Picked this up and had a bad power resistor solder joint, look at this pic, nothing like an old crt made in Japan still produces a nice pick.
Old 03-29-2016, 06:29 PM
Those Sanyo-built Sears sets from the mid '80's are good TV's. The CRT is probably either an RCA (EIA274) or Sylvania (EIA312).
Old 03-29-2016, 06:34 PM
The crt is a A48AAB26X.
Remember those well. IIRC labeled LXI.
Fun to work on & always ran nice. An underrated set.
Old 03-29-2016, 09:02 PM
dishdude's Avatar
dishdude dishdude is offline
Nice picture.
Old 03-29-2016, 09:13 PM
There should be an EIA number (probably in small print) on the CRT label.
IIRC, those sets had an oddball vertical module that is basically a few surface mounted components on a small PC board that solders to the main chassis. Sometimes, these will develop cold solder joints.
Old 03-29-2016, 10:12 PM
Well that's lousy because I lost several little paper stickers when I used a blow gun to get rid of the dust. It did have a sticker on it that said Sears.
