Old 12-01-2015, 08:35 PM
rca2000's Avatar
rca2000 rca2000 is offline
Motorola TS-612 set...Hot, cold, SS or tube ?
Motorola TS-612 BW set-Tube os ss- (sams 1035-1)
Can ANYONE here tell me what sort of chassis this motorola set has? it is a TS-612 (22TS612-A02). Is it a hybrid, or SS and is it hot or cold?
Hope someone has that sams--and can tell me..
Jack.
Old 12-01-2015, 10:30 PM
Probably all Solid state:
http://www.americanradiohistory.com/...-Page-0054.pdf
IFs, Video, Sync, H Osc are all transistors.
USN RET 22YRS (Avionics/Cal)
Old 12-02-2015, 12:04 AM
Hello Jack, The TS-612 has 28 transistors 1 3BL2 hv rectifier. Transformer power supply a very solid set. If the crt is good a good catch. I have 2 and they are good working sets, as are the ts-610 & 613 chassis. The later 2 have a/v inputs & outputs. All the best, Tom
Old 12-02-2015, 01:10 AM
rca2000's Avatar
So a cold SS set wiht HV rect tube, Any idea of the way the chassis is laid out it it a sort of "flat chassis" design? with a metal frame? Indeed I may have a lea don one of these...
Old 12-02-2015, 09:27 AM
Hi Jack, Yes metal frame flat chassis with a side panel for H-out & H.V. & side panel for tuners, transformers, front controls. All the best,Tom
Old 12-06-2015, 09:21 AM
Jack, were you able to procure the subject Motorola set? I think I came across the ad for it and was just curious.
