Old 08-07-2015, 06:18 PM
pendulum pendulum is offline
Interesting Montgomery Ward 1684 portable tv
Got this set today about an hour and a half away from me. I thought the set had an interesting styling to it and I haven't seen many montgomery wards sets around. This set seems like a pretty low end model, seeing how it doesn't even have uhf by 1963 -1964. The set also uses a somewhat oddball tube, a 16bnp4. Tests good but on the weaker side. I think the set must have been left in a damp environment because the inside of the cabinet has some surface rust. Looks like it only has a few paper capacitors. Will save to work on for when I am away at school but seems like a quick fix. I can't find any filter caps on this set though, which is odd. Set has a few tubes replaced but besides that it doesn't look like it was worked on. A lot of the tubes are made in Japan Wards branded tubes, which is interesting. This set is pretty close in age to the color Wards set I got
Old 08-07-2015, 06:23 PM
dishdude's Avatar
dishdude dishdude is offline
Wow is that a weird set especially with the tubes scattered throughout the cabinet. Japanese made? Any indication by who?
Old 08-07-2015, 08:16 PM
The set's the last of the Travler built sets. Made in Chicago or Indiana. Not the worst nor the best.
Old 08-07-2015, 08:26 PM
Thanks for the info, I never would have figured that out, though I assumed Montgomery Ward got others to build their sets. How were you able to tell, by the way?
Old 08-07-2015, 08:35 PM
Sure looks jap from the outside but one look at the
chassis screams USA.
A Jap set of this vintage would look packed & real messy.
Not to mention all those hex screws, not very Jap.
Old 08-07-2015, 08:52 PM
truetone36's Avatar
electronics packrat
I used to have a Truetone set that was nearly identical to your set.
Old 08-07-2015, 10:48 PM
I had a Travler branded set years ago, that was identical with the top and bottom chassis.
there was a label on top that boasted, "No Printed Circuits".
BTW, the electrolytic capacitors are under the lower chassis.
Old 08-07-2015, 11:35 PM
dishdude's Avatar
I totally missed all the hex screws.
Old 08-08-2015, 12:44 PM
That is perhaps the most 40's looking 60's set I've ever seen.
Old 09-14-2015, 09:47 PM
Recapped the set over the last week. Really simple restore, replaced all the super leaky ceramic caps, the 4 section electrolytic, and the open fusible resistor and the set came right up. I thought for sure the tube would be super dim, but it actually is very watchable. I did have to replace the 1b3, so maybe it was weak and causing low high voltage. Either way works good, looks much better than the photo I can take. Only problem, which I have had on other b/w sets, is there is hum when text comes on the screen. There is some dirt behind the safety glass, but I would have to remove the chassis and picture tube to get under it so some other time.
Old 09-15-2015, 12:00 AM
Try the side screws. Looks like the front hinges down & off.
Pull the nobs too.
