Old 05-15-2015, 08:26 AM
dtvmcdonald's Avatar
TRK12/120 Restoration
For some very sleepy reason I originally posted this on antiqueradios.com.
I'm moving it to here, the right place.
I am still at the beginning of my project to make a TRK12
out of the parts I picked up at the 2015 ETF convention.
I have not even begun to work on the TRK-12 TV, whose two chassis
came in crates, looking "almost" new and virgin ... but not quite!
There are a couple of 1950s shiny 1/2 watt resistors in there.
We won't know how late it ever operated until it is turned on and
the oscillator frequencies are measured. I have all the necessary replacement
caps. This evening I measured a substantial fraction of the resistors
that can be measured The resistor markings are odd .. its mostly
body - end band - next to end band - other end band is silver 10%.
They are all high ... but less high in the 1k - 100K range than
higher or lower. Replacing most will be lots less cosmetic trouble
than expected ... I'll just repaint the closest physical size in modern
resistors. There are dogbone power ones. The Candohms will get
shamelessly replaced with modern resistors on terminal strips.
Well, I'll probably paint them if the paint
I got can take the heat.
Paper caps are ALL absolutely bad
but look nice and will be very easy to restuff. Almost all wire is cloth and OK.
The radio, an RC-427F one for a TRK 120, is in sad shape.
It got rained on. There was rust on the back which I thougtlessly
removed before a photo. Some coils are toast and will get modern replacements.
All paper caps are so fragile as to be unrestuffable. I have not decided whether to
make new fake shells (not easy!), or just use raw yellow axials. Half the wire
is cloth and probably OK, half is plastic and falling apart and will be replaced
(with cloth). The mechanical works are dirty but not rusted and all the turners turn.
It will get a brand new eye tube and mount (TRK120s had no eye tube).
The cabinet is not actually bad. It can be used as-is. A restorer is coming tomorrow to
look at it.
This is going to take a lot longer than last summer's CT-100.
Doug McDonald
Old 05-15-2015, 10:21 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Today's word of the day is unrestuffable .
Good luck on the resurrection Doug. Keep us posted and post those photos, every one loves photos.
Old 05-15-2015, 01:37 PM
Steve McVoy's Avatar
Doug, I have a bunch of old paper capacitors you can restuff. Let me know what values you need.
I also have thousands of NOS prewar resistors. If you made a trip down you could go through them and probably find everything you need.
Old 05-15-2015, 06:50 PM
Here are photos of the TRK12/120 pieces, first set
of cabinet pictures. The last two are looking straight up,
camera sitting inside cabinet on bottom.
Old 05-15-2015, 06:54 PM
Rest of cabinet photos
Old 05-15-2015, 06:56 PM
First three are radio. other two are TV main chassis
Old 05-15-2015, 06:57 PM
The photos of the TV power supply. The radio power supply
is missing almost all parts.
Old 05-15-2015, 07:00 PM
Question is ... there is something missing in the mounting
for the TV chassis. It has been modified ... note the extra
holes in the front. These will be plugged and now veneer
installed covering them.
But where do the unattached wood pieces seen on the carpet go???
There is no way to install the TV chassis. Does anybody know?
Old 05-15-2015, 08:19 PM
vts1134's Avatar
Looking For Time
The hole size and pattern look to match the chassis for an RCA 630TS. It doesn't make any sense why that would be mounted down there, but that was my first thought when I saw the photo.
Old 06-01-2015, 07:03 AM
Progress report: I've found a cabinet restorer and it has been sent off.
I've found all hard to find pieces and have all but the radio power transformer,
which is supposedly on the way soon.
I've been working on the filthy radio chassis, which is now cleaned up.
Most but not all of the push buttons and the motor work. I'm now cleaning
up the tarnished push button switches. I have not yet decided whether
to take McVoy up on his offer and get usable old caps to restuff for it.
I can restuff the non-polar electrolytic for the motor. Almost all paper caps in the radio are actually open!
Old 06-01-2015, 10:09 AM
bigaudioal's Avatar
Good luck Doug! Looking forward to following this restore here on VK.
-Al
Old 06-02-2015, 12:33 PM
This TV's radio has seen lots of work in the past. Last night I finally got all the push buttons to work. The problem ended up being a very odd one: the mounting for
the whole set had been bent and the latching mechanism was preventing some
contacts from contacting when pushed in.
Also I noticed something for the first time: the motor had been rewired with the wire put on by hand! Its clearly the later light colored Nylon wire and is all scrambled
up. Also all the connections to it had been hacked off and reattached in a very
nasty and unsafe manner. However, they did make it work right. For somebody with a pristine one, how long is it supposed to take to go from one end of the band to the other? Its slow but acceptable.
Old 06-12-2015, 12:58 PM
The cabinet is back from the restorer. He did, in my opinion, a very fine job.
He did, however, punt on decal placement, making me do it with his help.
It came out great. However, there were only channel numbers 1-5 so
that's all we used. I hope they are in the right places, the gap is at
far right.
Also ... are the hinges supposed to have a detent for the correct
angle? They sure don't seem to, though they stay put perfectly well.
Pictures eventually.
Old 06-12-2015, 01:09 PM
tubesrule's Avatar
tubesrule tubesrule is offline
Sounds like you placed the channel numbers correctly.
There is no detent. The lid is designed to stay put at any position.
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 06-14-2015, 08:29 PM
The restored cabinet.
http://www.videokarma.org/attachment...1&d=1434331611
