Old 05-07-2015, 01:50 AM
TinCanAlley's Avatar
Avante Vertical Issue
Before I start pulling her apart I thought I'd stop by here and see if I'm going in the right direction with the current issue.
As of late, she's been a bit jumpy. The vertical size is twitching. The top and bottom 1/3 or so of the image move about half an inch in and back out. I'm thinking there is something wrong on the vertical module. Something affecting the V size or V lin.
So whatcha think?
Old 05-07-2015, 06:15 AM
Which chassis ?
Either one clean service switch & controls first.
Clean & re- seat module. Contacts can be tightened also.
IIRC there are few electrolytics on flat chassis.
IIRC only put an output in a flat chassis for no vert, never a
board.
Upright chassis you can use 9-92 or 9-147 module.
The newer 9-147 much better. BTW NEVER jump the vert fuse
on an upright chassis !
Old 05-08-2015, 09:35 PM
She's an 25EC58.
When I went over the chassis, I removed all boards, cleaned contacts, boards and deoxit/faderlubed all pots, etc. She's been working fine (other than jailbars) for over a year now. Since the jumping starts pretty much right after turning her on, I don't think it's a heat issue.
The vert module is a 90-83.
Old 05-09-2015, 09:30 AM
OK flat chassis.
A few other things.
If it still has plug in transistors they can give
trouble. Also the terminal strips are soldered to the chassis
on the ends & sometimes along them. They use them for
grounds. They can break loose especially on older sets.
Thats it for easy stuff, try tapping around.....
Old 05-09-2015, 04:48 PM
rrrhre2s rrrhre2s is offline
Try
C719 and C720 4.7 uf
Wet Slug Tantalum, Red capacitors... with one flat end...
Do not use a "regular electrolytic" capacitors they will cause linearity problems...
They are old enough to be going bad...
rrrhre2s
Old 05-12-2015, 04:26 PM
My Zenith tech topics suggests for the 25EC58 chassis to resolder all the vertical output transformer leads where they meet chassis connections - particularly those on the top of the chassis. The symptoms described in the Tech Topics is vertical pull up from the bottom, with convergence affected.
USN RET 22YRS (Avionics/Cal)
Old 05-13-2015, 09:31 PM
I found this at Mouser. Is it correct? I sure wish there was a place local that carried such things. Gets tiring ordering a couple bucks worth of parts and paying triple in shipping.
http://www.mouser.com/ProductDetail/...nE%2f%252bI%3d
Originally Posted by rrrhre2s View Post
Try
rrrhre2s
Old 05-13-2015, 09:32 PM
She keeps her convergence with the twitching. Her top comes down a bit as the bottom comes up a bit. As it gets closer to the center of the screen, it gets less noticeable.
Thanks
Old 05-13-2015, 09:33 PM
I'll pull and reseat the transistors. Need to get his fixed as I have the final season of SWAT to watch as well as Movin' On.
Thanks!
OK flat chassis.
A few other things.
Old 05-14-2015, 02:00 PM
Here's all the tech topics for the flat chassis - three pages, something on all of them.
Old 05-15-2015, 06:18 PM
Those would probably work.
If you have electrolytic capacitors you can try them it will stop the jumping just height and linearity will no adjust properly .
rrrhre2s
Old 05-18-2015, 01:10 PM
DavGoodlin's Avatar
Motorola Minion
Were these sent to Zenith Dealers? I never saw a format that gave credit like that before?
If so, the RCA dealers I worked for did not get anything like this.
Do you have any for 1964-72 color sets?
-Dave G
Old 05-18-2015, 01:36 PM
There was a guy selling yearly subscriptions to a repair list. He also sold one for the computer (386 - 486 Days). This was almost 22 years ago before I quit servicing TV's to make a living.
Used to carry them in a loose leaf binder for home service calls, sometimes saved loading up the set and transporting it back to the shop.
I now wish I had not gotten rid of them when I closed the shop in 1996.
rrrhre2s
Old 05-18-2015, 10:24 PM
They are from Zenith's Tech Topics - I have an incomplete set from 1970 to about 1978. Doug (DRH4683) also has some - probably more than I do. Zenith provided these to authorized repair centers on a monthly basis, and we always picked up a stack at the Zenith training seminar. I went to a total of 2, but my father went to several dozen Zenith training seminars, and some RCA, NAP and even Sencore seminars. I got my Dad's collection of service data from his shop - mostly older stuff, as he sold anything newer than 1998 to another service shop when he retired.
RCA had their "Goldenrod" supplements - orangish-gold paper supplements to their service literature. I've got from CTC53 - CTC90. Later, Thomson issued complete field trouble reports - three types - TV, VCR, and Projection. I have all three for the CTC175-CTC203 era, along with all of their ESI disks and manuals, along with a Chipper Checker suite - almost useless today.
I've got Sony, Hitachi, LG, Motorola, Zenith, Philco, and Panasonic/technics, Samsung. NAP and RCA data, much more than Sams covered - and I still have my Sams (sets 100-1900) Anything newer from Sams, I don't have....
And thanks to Bryan Gadow, I even have Sears service manuals for 70s-late 80s stuff, but no index.
Cheers,
Old 05-18-2015, 10:37 PM
rrrhre2s
There was a company called KDTV that had a database of repair tips for about 70 bucks, but 60 percent of it was useless crap like Sams cross references, model-to-chassis crosses, and parts subs. The remaining 40% was so Curtis mathes and Colortyme loaded that you got about 2000-3000 actual tips, and many were duplicates. They gave renewal credits for tips submitted, but no quality checking on the tips that were submitted, making for a very watered-down database. Repair World was okay, but got NAP heavy. Our best resource was other shops in our area, sharing helpful tips in phone conferences and a Sams-borrowing library. If you fixed a set, you marked up the Sams with the problem and cure. Some Sams had additional pages added - those were the problem sets like the System 3s, the GE AA/AB/AC chassis sets, and the RCA CTC175-185 sets with the EEPROM and tuner troubles.
Someone recently sent me a postcard about another online resource for an HDTV repair database - submit 20 tips and get a trial subscription. What a waste - board swapping isn't troubleshooting, and a database supporting that is not needed. Enough free resources exist - Vk, AVS forum and others for example.
Cheers,
