Old 04-18-2015, 08:47 PM
cchaven's Avatar
cchaven cchaven is offline
Camera video out question
What would be the best way of getting a composite video signal from my Concord TCM-50 into a VCR or a computer for recording?
I was able to cobble together a cable adaptation today that sent the video out from my Concord TCM-50 to an old Zenith ZVW-135 computer monitor. This cable chain consisted of: UHF adapter to F, a short 1.5' coax cable to a F connector adapter to RCA phono plug then a composite video cable into the Zenith monitor. I tried both the 75ohm and Hi-Z video inputs, with the inputs set to composite and I got a nice stable picture. The Zenith also has RGB input and dates from 1984.
I realize this cable setup isn't very elegant but it's what I was able to piece together for testing and I'm pretty happy that it worked.
Thanks for your help
Jeff
Sometimes you get more done on the simple machines. There's no complexity to slow you down and they're always ready to go.
Old 04-18-2015, 10:25 PM
Sounds like you've got what you need?
