Old 12-01-2014, 01:53 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Refurbishing Atwater Kent Pot Metal Pulleys
I started working on an Atwater Kent 30, and the first thing I noticed was that one drive belt was broken and all three pulleys were cracked and distorted. I did some research and found that these early pot metal pulleys usually needed to be replaced and saw some methods of producing new pulleys. However, the easiest route would be to pull some brass pulleys from a later AK model.
Easiest? I'll never fall into that trap! That's for normal people. Instead, I decided to refurbish the original pulleys by reinforcing them with epoxy resin.
Also, the bronze belts were in rough shape. A previous owner had even tried to solder the belts to the pulleys.
I let 3-in-One oil soak in for a few hours and removed each pulley in one piece--unlike the ones in the top photo.
To get good adhesion of the epoxy, I thoroughly prepared the metal: First, a degreaser cleaning in the ultrasonic to penetrate the cracks; then a water rinse followed by distilled water in the ultrasonic; then an alcohol bath to get the water out of the nooks and crannies; and finally overnight drying.
I brushed on the epoxy, trying to flow it into the cracks. When that was done, the pulleys were almost entirely coated with epoxy.
After 24 hours I sanded the epoxy back get roughly flat surfaces with particular attention to smoothing and properly shaping the perimeter surface that contacts the belt.
I cleaned the unbroken belt and burnished out most of the wrinkles. The pulleys got a quick coat of paint, and after it was reassembled the mechanism worked smoothly.
Well, this was all just for fun. I ordered new belts (adamsradio.com) and I picked up the cheapest possible AK 42 on ebay to get brass pulleys for the AK 30 and some power unit parts for my unfinished AK 42. Plus, now I'll have an extra set of pulleys, which is really good because you never know when you might get shipwrecked on a desert island...
Winky Dink
Damn the patina,
Full speed ahead!
Old 12-01-2014, 09:53 AM
powerking powerking is offline
I think the near future days of an affordable Joe Homeowner/hobbyist being able to make/reproduce any type of mechanical parts via a 3-D printer will be almost as revolutionary as the Internet. The 3-D printing industry is already using high-tech metal toner mixes. Scan in the part and hit print from your computer and there's your part in a few minutes. Amazing to me, and why this technology is being called the 3rd Industrial Revolution..
https://www.youtube.com/watch?v=JM0WfQGkAUE
https://www.youtube.com/watch?v=McDz...J5-1blE1h4YdTw
https://www.youtube.com/watch?v=KxiDwbFzWY4
Tom (PK)
Old 12-01-2014, 03:03 PM
Winky Dink's Avatar
Before hobbyists can obtain sophisticated 3D printers, a much wider selection of commercially produced "niche" items (such as knobs) should be available at much cheaper prices. But it's still more rewarding to find an original part or more fun to make one yourself.
Winky Dink
Damn the patina,
Full speed ahead!
Old 12-02-2014, 02:16 PM
stromberg6's Avatar
Nice job on the pulleys.
I once made a dial to cap coupler for a Stromberg 641 Treasure Chest out of an old brass combination lock bolt. Took most of a Sunday afternoon, but worked great, and I didn't draw serious blood in the effort. Have more bolts and more Strombergs, and Winter is fast approaching.
Kevin
stromberg6
Old 01-03-2015, 03:34 PM
stusnyder's Avatar
I would have used the intact one as a pattern for a sand mold, then cast new ones out of aluminum or brass.
BTW if anybody needs any small parts cast out of any metal I can do it.
Old 01-03-2015, 07:35 PM
Winky Dink's Avatar
I don't expect to start metal-casting myself, but I am curious. Let me throw a few questions:
What type of metal?
What melting point?
How do you heat it?
What do you heat it in (crucible)?
How detailed is the casting?
Do threaded holes have to be machined?
Did you see the show about the retired alloy casting guy who made fake tokens that would fool high-dollar gaming machines?
Thanks. I'll keep in mind your casting capabilities.
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-03-2015, 09:56 PM
stusnyder's Avatar
What type of metal?
What melting point?
How do you heat it?
Sure winky,
metals include copper, brass, led, aluminum, and cast iron.
Never measured melting points.
oxy acetylene rosebud torch
metal ladle lined with sand and core wash to hold the sand in place
The sand is super fine, amazing detail
yes you must clean up and tap holes
No i did not see the show, but have made pieces for cast iron toys and old slot machines in the past that fooled experts.
In fact now that I moved and got settled in I'm going to cast some of those brass lamp shades that are always missing on the rca radiola's.
Old 01-04-2015, 01:17 AM
Winky Dink's Avatar
Thanks. These processes have always fascinated me ever since I was a kid trying to make pennies with aluminum foil molds, plaster, and paint. Even at 10 years old I eventually realized that it was cheaper to buy them.
Winky Dink
Damn the patina,
Full speed ahead!
Old 01-04-2015, 08:09 AM
stusnyder's Avatar
This is a dying trade. The man who taught me passed away a few years back.
Old 01-04-2015, 12:57 PM
Gregb Gregb is offline
Hey Stu:
Have you thought about how the lamp hoods will attach, were you going to cast the metal retaining tabs into them? Put me down for one of those, I could use one.
Thanks
Gregb
Old 01-04-2015, 03:53 PM
stusnyder's Avatar
Originally Posted by Gregb View Post
Hey Stu:
Thanks
Gregb
Yea the one I got has those 2 tap things on it, and it's the only one I have. I'll make a pattern from it, and cast the rest from that pattern.
I'll have to make up a new mold box first.
Old 01-04-2015, 11:52 PM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
I'd suggest entombing something with the tab sticking out into the mould. "Cast" anything is usually quite brittle (Copper excluded.) and they may not even bend over once for installation without snapping.
Old 01-05-2015, 04:42 AM
stusnyder's Avatar
I cast them out of a softer brass so they wont snap off.
Old 01-05-2015, 09:11 PM
Reece's Avatar
Reece Reece is offline
Stu, you PM'ed me yesterday and I tried to answer but VK says you have it set not to receive messages. Could you fix that and PM me again?
Reece
Old 01-06-2015, 05:12 AM
stusnyder's Avatar
I checked ny settings and everything is correct, I have been getting pm's from others.
