Old 10-07-2014, 10:04 AM
selenium focus rectifier
hey guys , is there any positive way to test a focus rectifier stick, an rca 113397?
Old 10-07-2014, 10:51 AM
I've never tried to test one, just replaced it. The internal resistance is too high. Same is true with the boost diodes.
A lot of them aren't easy to replace. On the CTC15 and clones, the HV cage, has to be disassembled.
Old 10-07-2014, 11:05 AM
well i found out recently that the boost diode i believe if it shows resistance in one or both directions its bad. because testing with the dvom normally shows nothing and i had a bad one in one of my sets and sure enough the new one did the trick and the old one did show resistance.
Old 10-07-2014, 11:49 AM
Focus sticks we just changed. You can measure the HV
on the cathode & be sure its abt 6KV or more then work
your way through the resistors, pot etc.
If you cut one open its a stack of little discs in series so
the voltage drop realy adds up.
