Old 05-17-2014, 08:11 AM
Marco-nix's Avatar
Post Question about a CRT.
Hi all again..
2 have a dilemmas... I have a Sylvania with a crt with no label on it, so I can't tell you the number...
the other tv is a Philips with a crt ... probably universal made in Montréal but I don't know the number on the picture tube.
My question is: is it dangerous if I swap the CRT from one to the other ?
What is the danger ? the both picture tubes have the same size ...I want to keep my Sylvania...
Brand : Sylvania
Model : CL9226P
Chassis : E45-1
Serial Number : 1121990
What are the substitutions for the Sylvania CRT 25'
Old 05-17-2014, 10:26 AM
How old is the Phillips ? The E-45 was a delta CRT IIRC newer
jugs wont work. Remember you need it to be both
electricly & physicly the same. Maybe someone has a sub book
& can give you a list.
Old 05-17-2014, 02:50 PM
Marco-nix's Avatar
ok zeno but I also have a Sanyo
Brand: Sanyo
manufactured : 1988
Number of the CRT : A63JHF31X
date for the tube : 09-22--88
AND
My sylvania is a 70's and i have no informations( the papers are not Inside and gone
What is the danger if I put a CRT that doesn't fit in my sylvania ?
Old 05-17-2014, 03:55 PM
Well, without a sub book, and numbers, you can compare the two side by side.
Make yourself a pinout map of both tubes as far as what you can see from the outside.
Be sure you can see the wires going to each element. Map it all out well, be sure the
key points to the same spots etc.
When I was in tv school me and another joker swapped picture tubes, delta's, one was
longer, and the screen curve on front was not the same. It worked, but we couldn't
put the back on without putting a extra bump on top of the original tube bump, good thing
it was a plastic cabinet, we melted it together with soldering irons.....
I think you should check out for compatible filaments too, volts and pins.
If you guys didn't get to do this stuff in high school, well, you missed out big time.... Lots-a-fun!
Old 05-17-2014, 04:08 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Fortunately for me, I found out that the picture tube I salvaged from that rotten Hitachi was also used in one of my dream sets. On the down side, I have no way to test it.
Old 05-17-2014, 04:41 PM
Marco-nix's Avatar
If I understand, it's dangerous to swap a CRT to another tv ...
Old 05-17-2014, 04:42 PM
Marco-nix's Avatar
and BOOOOOOOOOOOOOMMMM !! isn't it ?
Old 05-17-2014, 06:24 PM
CRT's are surprising interchangeable. As long as deflection angle, gun type, HV rating(not as much of an issue in color due to standardization), and mounting are reasonably close minor tweaking can often compensate for the rest....Sure it won't be perfectly original, but it will work.
Old 05-17-2014, 07:40 PM
Brand: Sanyo
manufactured : 1988
AND
The Sanyo tube will be an in line gun CRT. The older Sylvania will have a
delta gun so wont sub. Funny thing is the Sanyo tube was probably
built by Sylvania, they built most the tubes for Sanyos used in the US & Canada.
My E-45 manual is missing but the E-46 uses the following CRT's
25VDMP22
25VCZP22
25VDXP22
This was probably the best of the Sylvania chassii.
For the uninitiated a delta gun CRT has the 3 color guns arranged in
a triangle like the Greek letter delta. An in-line CRT has the 3 guns
arranged in a straight line & a more modern design.
Old 05-17-2014, 10:15 PM
Marco-nix's Avatar
Zeno, tell me the difference between an E-45 and E-46.. because i probably have a CRT beginning with a 25VDM..... and if it will fit in my Sylvanya..
Old 05-18-2014, 09:36 AM
Looking at the E-46 manual it looks like the E-45 but its been
a long time since I worked on one so not sure. Did you look
at the layout chart in the set ?? Sylvania had a lot of info
on theres & maybe the CRT number is on it.
Old 05-18-2014, 10:18 AM
sampson159's Avatar
sampson159
there is no e 46 chassis in a 25 inch set.the next in series is e 48.the crt will interchange with any 25v delta gun.i own e 45 and e 48 sets right now.the 25vdmp22 was the best looking crt ever made.didnt last long but they made the best picture.
Old 05-18-2014, 01:53 PM
Marco-nix's Avatar
No not yet because my Sylvania is in a basement at the house of a friend and this set is at almost 50 miles from me, When I will have the time I will tell you the other informations about it.
Old 05-18-2014, 01:57 PM
Marco-nix's Avatar
However I measure from a left corner in diagonal to the other corner up right. Where am I wrong ?...Sorry for the bad English I speak french ....
Old 05-18-2014, 02:58 PM
sampson159's Avatar
sampson159
are you measuring the crt?if so,just measure from corner corner diagonally.what is the number of your crt?
