Old 04-23-2014, 12:43 AM
tvcollector's Avatar
Sony Betamax SL-2300
I just got one of these locally fairly cheap.. It's got the common tracking lines and flutter problem.. I did a research and from what I found, it seems the common problems on these are the tracking pot.. I did measure with my ohm meter and it reads pretty much the same when adjusting the control.. I don't have the service manual for this unit yet, so I don't know the values.. I did try to find a replacement part, and didn't have any luck.. So I don't know if this is something I could just get from Mouser or Digikey once I find out the specs, or if it's a part that was made for the unit and not any on board pot control would fit.. Maybe someone here knows a quick fix?
Old 04-23-2014, 06:55 AM
Hello these model of beta vcr are also known to have problems in the servo circuit with bad caps check those first before ordering any parts also a quick fix is to adjust the capscan speed...
Old 05-14-2015, 07:26 PM
djfivos djfivos is offline
Yeah...bad capacitors in the servo!
