Old 01-11-2014, 06:10 PM
YamahaFreak's Avatar
<-- CSXT 6038, EMD GP40-2
DLP TV black and white frozen screen
(Thought I'd make a new thread to avoid derailing the original.)
This is an issue with the same Samsung HLN437W TV as before. Recently, the screen has been locking up in a weird, all black and white (two-tone, not grayscale!) screen. Sound and controls still work, and the only way to fix the problem is to restart the TV. I have been unable to figure out anything I or the set have been doing that might trigger it. Some days the set will run for hours and hours with no problems at all; tonight, the screen froze before it was running for five minutes.
Attached is a photo of the condition.
Sony Trinitron Fan
Old 01-11-2014, 11:49 PM
rcaman's Avatar
rcaman rcaman is offline
dmd board is the problem
Old 01-12-2014, 12:05 AM
Can you elaborate? Is is possible to replace componentry on the board rather than the entire board? I just spent $50 to replace one board and would rather not spend that again to replace another unless it's absolutely the only way to fix the problem.
Sony Trinitron Fan
Old 06-12-2014, 03:02 AM
This set is at it again. It went for months with absolutely no issue whatsoever, and now, it won't run at all for more than ten seconds without locking up. Much more chronic than before. Sometimes the screen won't come up at all (beyond stray light from the lamp on the mirror), sometimes the screen freezes B&W, and sometimes it just shuts the picture off. I'd really like to know exactly what and where the problem(s) is/are, so I can repair/replace and get that fantastic picture back.
Sony Trinitron Fan
Old 06-12-2014, 04:43 PM
miniman82's Avatar
First Light: 1952-2011
http://www.ebay.com/itm/Samsung-DMD-...p2054897.l4275
Evolution...
Old 06-12-2014, 05:15 PM
While I appreciate the link to the board, this is essentially the same answer I was given earlier. Is there no way to perform a component-level parts replacement on this board? Is the failed item an unobtainium, SMD, or otherwise unreplaceable IC, or could it just be a capacitor or two?
Sony Trinitron Fan
Old 06-13-2014, 01:34 PM
miniman82's Avatar
Good luck with that, you'll waste $1,000 of your time replacing a part on an $80 board. Nut up and buy it.
Evolution...
Old 06-13-2014, 02:08 PM
That board has thousands of surface mount parts, even in the unlikely event you could isolate the one bad component the chances of replacing it are slim, both from a parts standpoint and because it's microscopic surgery. All that stuff was installed by robots, while it is possible to replace a SMD in some cases it's not all that easy to do without damaging the board.
Old 06-13-2014, 02:57 PM
It has nothing to do with 'nutting up' and everything to do with being jobless and having $180 in savings. I cannot afford anything that isn't free or close to it right now.
Eric's reply is exactly the sort of response I was looking for; he gave me an answer and a reason why.
Sony Trinitron Fan
Old 08-07-2014, 05:36 AM
Looking at parts at this time. For clarification, is the problem with my set the DMD BOARD, or the DMD CHIP itself?
Sony Trinitron Fan
Old 04-17-2015, 10:18 PM
Success
I found a cheap DMD board with the DMD chip itself on that auction site (saved the new DMD as a spare, or if someone here needs it) and installed the board. The TV has been operating flawlessly for 48 hours now. Once again, thanks much to all of you for your help and insight!
Sony Trinitron Fan
