Old 12-31-2013, 04:57 PM
dauberich's Avatar
dauberich dauberich is offline
Location: Hannover, Germany (..where PAL was born! - so Telefunken said)
Manual needed for a Hitachi Z-One
Hi.
I just bought a Z-One on ebay. First I thought the camera will only be good for the showcase as the color bar was the only o.k. signal.
But then I unscrewed the four screws on the front and took out the optical block to see that all cables were unplugged. So there is a chance..
Unfortunately, there were only two sockets for the 6 cables in the housing of the block viewable. So the other inputs I guess, must be located somewhere in the lower box where some of the switches are or even someplace else. But before I disassemble every part and cover of the camera, I hope to find someone with a service manual telling we where the cables have to go to.
I found the operation manual already on the net, but of course there weren't any information given about where the cables have to go.
So can anybody help me with that? Does anybody own a Z-One service manual?
Thanks for your help on that!
Stefan
Old 01-16-2014, 03:53 PM
BetacamSPMan BetacamSPMan is offline
I used a Z-one for my first corporate video project back around 1991? I really liked the camera a lot. I know someone with a Z-one, but have not talked to them in several years, I will see if I can find them on facebook.
The Hitachi models that followed, the Z-one B, and the Z-one C were vastly inferior. There was a term that came out in the 90's which I have forgotten in which the camera automatically increases contrast as the camera zoomed out. One of the dumbest if not the dumbest "innovations" of the 90's.
Old 01-19-2014, 03:14 AM
dauberich's Avatar
Hi.
We'll,that's good news!
I hope the Facebook search ends up successfully.
Would be the first time there really is something Facebook is good for. ;-)
So you say the type b and type c follow-ups of the z-one were poorer than the first type? And the "auto contrast" was really coupled with the focal length? We'll that really sounds stupid (..the fact), especially if they made the gamma stronger in the wide shots where normally the contrast is stronger anyway,. sure it wasen't the other way round? Compensating the pictures' softness in telephoto by increasing the contrast there?
We'll in every case it would be something that takes away control from the cameraman, so it isn't helpful anyway.
Well, if Facebook really shows up with a link your former z-one joint user it would be nice to ask them for the service manual. Thanks!
..as you are the betacamSPman: I just received a camera (JVC KY-27) with a docked PVV-1 Recorder. to my surprise the pushing of the lens' return knob only gives me a still (!) playback picture but not the usual 3 to 5 seconds playback you can use for checking your last scene or for making sure that the backspace editing is working properly and lets you have a clean cut between the recorded takes.
Could it be, that this is one of the features they dropped to make the PVV-1 a cheaper alternative to a"regular" BVV-5 or PVV-3 recorder?
As the docking port is different to the BVV-5s (the long vertical instead of the small horizontal) I cannot check it by just changing the PVV-1 to a camera where the return- function is present now with a BVV-5 recorder.
And as I did not find a operation manual yet, I cannot check the diagnoses- option to see whether there is an option for selecting the type of record review- reaction the recorder will provide.
So can you help me with an information and/or the manual on the recorder?
Thanx a lot!
Stefan
