Old 10-12-2013, 01:46 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Talking Looky what followed me home
I was out with my sons today, doing some thrift store running (I had to find a few metal folding chairs), and we decided to stop by the Buffalo ReUse center, one of those places run by Habitat for Humanity. My eye was caught immediately by the back of a Zenith tube set sulking by the bay door. Looked at the front, and son of a gun....a Space Command 300!
I went inside up to the desk, and said "hi, you've got an old Zenith TV sitting by the loading dock?" He said, "God bless you, haul it away if you want it'. Sounded like they didn't want it but had no idea how to get rid of it or what to do with it.
So I did! It just fit in the trunk of my Cadillac DTS. It appears that it sat somewhere that wasn't good for it, as the top is warped up on the corners....but there are no water spots on it. Turned on my agile modulator in the house, and powered it up on a variac in my garage. Sonofabitch, it works!
Even the motor for the tuner works too! Time to clean it up and bring it in the house, where I'll treat it to a cleaning, some fresh caps, and then I can watch me some tee vee
Old 10-12-2013, 01:50 PM
egrand
Guest
Posts: n/a
Some days are diamonds, some days are stones. Congrats, today was diamonds for ya!
Old 10-12-2013, 02:42 PM
Some people have all the luck! Good on you!
Old 10-12-2013, 03:14 PM
Score One for the Good Guys !
Old 10-12-2013, 04:59 PM
Kamakiri's Avatar
Got it in the basement, and it's hooked up. It's gonna need some work.....a spring of some kind popped off the tuner when I went to change channels, and the motor seems to freewheel....I can't get the motor to stop unless I change the channel manually from the back. LOUD hum in the audio on channel, and the height, while perfectly linear, isn't adequate.
Minor issues that a recap and a run through of the tubes will more than likely fix. At least I have plenty to work with here. Picture is so bright it'll hurt your eyes
Old 10-12-2013, 05:33 PM
Congrats on your find keep us posted with some photos I have 2 from 1959 console needs work portable does not there were 2 remotes for that set on the bay excellent save...Timothy
Old 10-12-2013, 06:13 PM
Nice catch ! 14N22 chassis ???
Motor is rocker switch on rear where the stop/skip tabs are. (usually)
Gets dirty & sticks.
Old 10-12-2013, 09:13 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Bitchin' score! I got pretty lucky at the thrift store today too. Nothing on my wish list, but a good day there nonetheless.
Old 11-25-2013, 04:36 PM
Kamakiri's Avatar
I couldn't remember for the life of me what was wrong with this set, so I powered it up again. Keystoned raster that won't fill out. Are we looking at another yoke replacement like the last Zenith 23" black and white I just got done with?
Trying to decide if this is a parts set, or if I should give it the works.
Old 11-25-2013, 06:22 PM
TVTim's Avatar
TVTim TVTim is offline
Sure is nice looking. Think about repairing it.
Old 11-25-2013, 07:19 PM
It doesn't look keystoned from here, just short on height.
Old 11-25-2013, 07:58 PM
Kamakiri's Avatar
Wrong word. Pincushioned, I should say.
Old 11-25-2013, 10:27 PM
Have you tried adjusting the vertical height control, replacing the vertical oscillator-output tube, or both? I'd try one or the other before even thinking of replacing the yoke.
Old 11-26-2013, 05:14 AM
Kamakiri's Avatar
Oh yeah, tried all of that. My inclination here is to just yank the chassis and start with a full recap as I usually do (tubes were tested and the controls tweaked). To be honest, I think I was kind of looking for an excuse to part the set out because space is getting a little tight down here.
But, out of the 21 sets that I own, 13 are fully restored and functioning, and 4 more are in progress. I'd only call one a parts set, a locomotive, and even that's probably restorable eventually. And it's gonna be a LONG winter. Might as well order up some more caps to replenish my stock and get to work.
Old 11-26-2013, 07:44 AM
Jon A.'s Avatar
Part out a Zenith in such good shape? No way man!
